09-24-2003, 06:08 PM
What's Normal?
Ok folks, what's the "normal" range of oil pressure for a 302 with a standard volume/pressure oil pump? How about on an engine with less than 100 miles on it?
Greg
09-24-2003, 09:02 PM
If you're running bearing clearance up to .0025, you should be fine with about 10psi per 1k rpm.
What are you seeing?
'89 LX 408...SCAT, Probe, AFR 205, Vic Jr, Pro-Systems, Rawls sft cam, UPR K & arms w/coil overs.....more to come!
09-25-2003, 05:14 AM
Cobra Make, Engine: ERA 289 FIA #2086, 302/320 HP, Dart heads, hydraulic
Greg,
Oil temp at 180-190 degrees, 2500 RPM, around 65 PSI. Idle can vary a lot but somewhere in to 25-30 range. Normal rod and crank clearances are at 0.0025"
With cold oil you may see 80+ pressures on startup.
If you can't get your oil temp up - you might consider a bypass/thermostat for the oil cooler.
09-25-2003, 05:45 AM
Thanks Jim and Joe. I am seeing 80+ at startup, and then 90-95+ at 3000rpm after running for 5-10 minutes. For now I am running w30 Pennzoil. I don't have the oil cooler plumbed yet, but guess I need to give the oil more time to warm up. Any thoughts?
09-25-2003, 09:22 AM
I'm running 60-65 psi at full temp. 80 psi when cold. Even at idle I'm still doing 40-50 psi. 20-50 oil. This was/is a brand new right from the manufacturer 302 engine with about 20K miles on it. Not a rebuilt or crate motor.
Ernie
09-25-2003, 01:33 PM
OH
Cobra Make, Engine: Everett-Morrison, 347 Tri-power Stroker
5W-30 Oil;
65lbs cold at idle (1000rpm) about 75lbs off idle.
45lbs warm at idle (900rpm) about 60lbs off idle.
- Dan
09-25-2003, 03:11 PM
Greg,
You might want to consider using 10W30 or 10W40 instead of 30W. A thicker oil will give you more pressure but less flow, more flow will run the bearings cooler.
BTW, I have an oil cooler installed, but not hooked up. Joe Lapine (who built my 302) said it just wasn't needed except for track use. So far he has been right - without a cooler my oil has never gone over 190 degrees.
09-25-2003, 04:27 PM
Ernie, Dan, Jim,
Thanks. Since I wanted to change oil soon anyway I think I'll give 10w-30 a try.
Jim, when I hook up the oil cooler I will use a thermostat. You are right about only needing it for track time, and I know oil that is too cold is not good.
Greg
09-25-2003, 04:38 PM
Jim has it exactly right, pressure does not equal flow! I would consider a 5W-30 synthetic. Avoid the Fram filter.
09-25-2003, 05:03 PM
Bob,
Yup, no Fram's on any of my cars. I stick with Motorcraft on my Ford's.
I will definately switch to a lighter multi-viscosity oil this weekend. I won't switch to synthetic yet as the engine still has less than 50 miles on it. After I have a few thousand miles on the engine I definately will switch to synthetic.
Greg
10-26-2003, 10:59 AM
High Volume Pump was the problem
Well I tried switching to a lower visocity oil (5W-30) and that did not help. So I decided to tear of the oil pan and check the oil pump.
After comparing the installed pump with a brand new standard volume pump it turns out I had a high volume pump, not a standard volume as I assumed. The depth of the pump rotors were deeper than the standard volume pump (more surface area, hence more volume.)
Anyway... installed a standard volume pump and now my oil pressure is 60-65lbs off idle with cold oil at start-up. By the time the engine warms up and idles steady the pressure is 45lbs. After warm and revving to 5000rpm the pressure goes to 65lbs max.
Sounds good to me.
Greg
