Old 12-06-2003, 04:43 PM
V-8's Avatar
V-8 V-8 is offline
Cobra Make, Engine: 67 Mustang with Eleanor body kit.408w+250hp NOS with alcohol
Send a message via MSN to V-8
Default dui ignition
i have got dui ignition street/strip.what are you thinking about dui? what would you prefer?
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
http://www.clubcobra.com/photopost/s...at=500&thumb=1
http://www.motorspor.com/index.cfm?f...r&haber_id=250
http://fordboss.blogcu.com/1967-must...leanor/5605130
http://www.auto-drom.com/haber-trtuning.htm
http://www.motorspor.com/index.cfm?f...&haber_id=1897
Old 12-07-2003, 10:57 AM
V-8's Avatar
V-8 V-8 is offline
doesnt anybody using dui ignition on his/her ford!!!???
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
Old 12-07-2003, 01:20 PM
Ron61's Avatar
Post
I can't help you as I never heard of DUI ignition. Do you know what company makes it? Most of the people around here run either Jacobs or MSD.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 12-07-2003, 01:26 PM
Driving Under the Influence?
So, this thing won't let you drive if your drunk or what?
Ernie
Old 12-07-2003, 01:30 PM
Ron61's Avatar
Question
Ernie,
Notice that the post is from Turkey. Maybe this should be referred to Turk.
Ron 61
Ronnie Widener
Old 12-07-2003, 05:54 PM
Cobra Make, Engine: Everett-Morrison, 434 cid
Performance Distributors, Davis Unified Ignition a.k.a. D.U.I. is an H.E.I. for Fords. I had one on a '66 390. Comparable to a race HEI for Chevys, very good piece.
Scott
Old 12-07-2003, 06:03 PM
Ron61's Avatar
Smile
Scott,
Thanks for explaining that. I had just never heard of it. Was it an aftermarket unit or did it actually come from Ford? I am familiar with several of the H.E.I. systems, so now I learned something new.
Ron 61
Ronnie Widener
Old 12-07-2003, 06:08 PM
Here you go
http://www.performancedistributors.com/
Old 12-08-2003, 07:20 AM
Ron61's Avatar
Thumbs up
Thanks Scott. Looks like a pretty good set up.
Ron 61
Ronnie Widener
Old 12-08-2003, 12:03 PM
V-8's Avatar
V-8 V-8 is offline
ron61;
i think you should learn a lost of thinks...
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
Old 12-08-2003, 12:14 PM
V-8's Avatar
V-8 V-8 is offline
Scott
thanks for infos scottj;
some guys tell me, dui is not a good ignition because module in cap get warm and it start to make miss fires.
they suggested msd pro billet and msd 6al.
but i have got no problems with dui (since 2002 may)!
have you got or heard an problems with dui?
thanks...
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
Old 12-08-2003, 01:12 PM
Ron61's Avatar
Smile
V-8
Obviously both of us have a lot to learn. I don't claim to know a lot and you obviously didn't know much about that system or you would not have posted the question. Just read the posts and we all learn. Have a great day.
Ron 61
Ronnie Widener
Old 12-08-2003, 01:13 PM
V-8,
I have seen some stock Chevy HEI modules fail and it was always attributed to heat. Everyone running HEI always kept a spare module in his or her toolbox. Usually any problem with the module was corrected when it was replaced. I never had a problem with misfire or complete failure with the DUI though. I don’t think it would be accurate to say this type of unit misfires when it is hot.
I run a Pro-Billets, 6AL's, and Blaster 2's in my cars now. I have had MSD boxes and MSD coils go bad. Now days, everyone I race with carries a spare MSD ignition in their trailer or they run two and switch to the spare if one fails.
Scott
Old 12-08-2003, 03:15 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Like ScottJ said, the DUI (Davis Unified Ignition) is a Delco HEI ignition for Fords. I looked at one. Seemed a little pricey for an HEI setup although compared to a vintage Ford distributor, it's certainly an improvement. And for a Cobra it seemed a little too tall, and might cause hood interference problems. Don't know.
But I'm using the pretty much standard MSD Pro Billet distributor (which is also a Delco style dist), and MSD 6A and it works fine.
Old 12-08-2003, 08:05 PM
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
V 8,
Your English is a lot better than my Turkish or Arabic. Good for you! Don't let any comments made by these people bother you. Believe it or not, is is mostly all in fun.
You might consider a simpler and less expensive option. Mallory makes a very good distributor called UNILITE. It is breakerless, just as the DUI and HEI are. It uses light instead of magnetism. You must use a coil with it, just like older distributors do.
I used the UNILITE distributor with a high voltage coil and 8mm wires on my 427 Ford engine and on the dynamometer, (an engine test) it produced nearly 500 horse power.
With this combination, I had absolutely no misfires and never had to replace any parts in the distributor. It is also very easy to install and connect.
Another item is size. The Mallory UNILITE is the same size and shape as a stock breaker point distributor. The DUI and HEI units are much larger. They can be a nuisance when running the spark plug wires close to carburetors and throttle linkage.
Good luck to you V 8. Let us know if we can help any more with this.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
