LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 12-31-2003, 10:10 AM
V-8's Avatar
V-8 V-8 is offline
Cobra Make, Engine: 67 Mustang with Eleanor body kit.408w+250hp NOS with alcohol
Send a message via MSN to V-8
Default 351w 4-bolt milodon caps
http://store.summitracing.com/defaul...part=mil-11420
i want to add strength for my 351w standard block.the main caps are angled bolts.is it good?
Or only main girdle okey for upgrade main caps?
http://coasthigh.com/Main_Girdles/Main_Girdle.htm
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
http://www.clubcobra.com/photopost/s...at=500&thumb=1
http://www.motorspor.com/index.cfm?f...r&haber_id=250
http://fordboss.blogcu.com/1967-must...leanor/5605130
http://www.auto-drom.com/haber-trtuning.htm
http://www.motorspor.com/index.cfm?f...&haber_id=1897
Old 12-31-2003, 01:54 PM
Contemplated Milodon 4 bolt caps when doing engine. They are available for the 351W.
Most factory heavy duty truck, marine, and hipo automotive engines have 4 bolt mains on center 3 caps.
Two schools of thought for retrofit. The factory 4 bolts were anticipated to see a lot of strip and track use. If you anticipate strip, track, supercharged street, nitrous street, then retrofit 4 bolt mains along with aftermarket forged rods, and pistons.
If this is mostly street with a burnout from time to time, most of this bottom end beefing is a waste of money. Use ARP studs and the 2 bolt caps are fine. The stock crank is fine. The stock rods, provided they have been reworked for hipo street use are fine. hypereutectic KB pistons are fine.
However, a windage tray, and a baffled style Road Race oil pan is a good investment for a Cobra motor. Cobras, even street only Cobras experience more violent acceleration, decelleration, and cornering and need positive oil control.
Old 01-02-2004, 11:09 AM
Cobra Make, Engine: None Yet
Very difficult if not impossible to install 4-bolt caps on stock blocks after mid 70's because main webs were made smaller / lighter and there is no flat machined surface to mate with the flat bottom of the 4-bolt main cap to.
auto10x
Bill
