Old 02-01-2004, 08:31 PM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Default Larger pulley (what impact will it have)
Bought a set of serpentine aluminum pulleys but they did not make one for the a/c eliminator pulley. Finally found one and sent away for it but its 4 1/4" compared to the stock 3" one. What if any effect will this have on the water pump and alternator. Will I need to worry about overheating or undercharging?
Thanks
True
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 02-01-2004, 10:05 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
A larger pulley slows the rotation of the part it is on...a lg alt pulley will spin an alt slower, producing less charge at high rpm. On a street car, I would keep the stock pulleys unless you are going to rev pretty high all the time. Esp on the h2o.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 02-02-2004, 03:54 AM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
First off the ac eliminator will have no effect on engine drag as it is just another idler pulley.
The thing to remember about pulleys is that on an engine it is the relationship between the crank pulley size, (drive pulley), and the driven pulleys.
Think of it as a 10 speed bike. The closer the pulleys get to each other the slower the driven pulleys turn.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 02-02-2004, 10:47 AM
zipzip's Avatar
Cobra Make, Engine: Midstates work in progress, personally built 302
Pay attention to what Bruce said... Unless the pulley is actually connected to something, it does nothing but increase the belt length needed to wrap around everything.
The ratio between the driving pulley (crank) and driven pulley (alt or pump) is the ratio you should be concerned with.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
