Old 02-04-2004, 05:18 AM
69 Mach I's Avatar
Cobra Make, Engine: No cobra YET. Making do for now with a 69 Mach I
Default cam shaft question
I have lurking here for a bit and finally have a question to post. I have to choose a new camshaft for my 1969 351W. I see that I have a choice between a flat tappet and a hydraulic roller cam, with the latter costing 2x the price of the former. How do I tell if my car (1969 Mach I) came from the factory with a hydraulic roller cam or not?
ttfn,
jerryS
Old 02-04-2004, 05:52 AM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Jerry,
The 69 came with a flat tappet cam shaft. Ford did not use the rollers till much later. Late 80's if I remember and in the 302 to start.
You can install a roller cam in the 351w but you will have to modify the lifter valley to use the Ford tie bar retainers for the roller lifters and a few other items will have to be changed.
Stick with the stock style cam unless you are racing. It will cost less.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
