November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-28-2004, 10:34 AM
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
Question header problem
Guys,
I am constantly having to tighten my header bolts. I actually lost two on a 50 mile run last week. This is driving me nuts! Is this common, or will they eventually stop loosening up? I have a 351W with aluminum (Edelbrock) heads and Backdraft split headers. The car is fairly new with only 650 miles on it. I have tightened them about 5-6 times when cold. Any ideas here would be helpful.
Old 02-28-2004, 11:16 AM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Check your local speed shop. You can pick some up header bolts with a snap ring that you install after the bolts are on and tight that will keep them from backing out.
Always use a good header gasket not the cheap ones that come with most headers. The good ones will only shink a small amout were as I have seen others get very hard over a short time and blow out as they get smaller.
As far as gaskets go you get what you pay for and that really shows up on header gaskets!
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 02-28-2004, 11:22 AM
Unique580hp's Avatar
Cobra Make, Engine: Unique Motorcars 427 Cobra. 427 Side Oiler. Dual Quads.
Also,
If you have rubber motor mounts and solid sidepipe mounts and solid collectors, something has to give when the engine torques. This is usually the header bolts. Headers have even been known to break at the flange because you have a rigid system and a moving motor.
Just yesterday I had a rubber gasket put put between my sidepipe mounts and frame.
1st car was a Cobra, hopefully my last will be also!
Old 02-28-2004, 11:27 AM
Cobra Make, Engine: 2004 Kirkham 427 Roadster. New BBM Sideoiler Block, 484 cu. in. built by Valley Head & Racing Engines, Northridge CA. installed 3/20/2016
SkipB
The easiest thing to do is call Stage 8 Locking Fasteners 800-843-7836 in San Rafael Ca. 94901, stage8.com. They have a great product for all kinds of things, headers, starters, oil pans etc..
Or you can drill and safety wire your bolts, which has been the norn for years.
Good Luck
Bruce
Bruce
Old 02-28-2004, 03:20 PM
Roscoe's Avatar
As an alternative:
I could not fit the bolts with the snaprings on my headers. I got a set of stainless header bolts drilled for safety wire from Totally Stainless. I wired the bolts in pairs. No more problem.
http://totallystainless.net/totally.html
Roscoe
Roscoe
Old 02-28-2004, 05:40 PM
DAVID GAGNARD's Avatar
My Ford F-150 used to do that,I just put lock washers on the header bolts,works fine....
On my Mustang,I have the ones with the half-moon-snap-ring looking thing,they work great also....
David
DAVID GAGNARD
Old 02-29-2004, 10:14 AM
Thanks for all the replies and good ideas. I may have to go the safety wire route as the Backdraft headers offer very little clearance. It is even difficult to get a wrench on the bolts. I am sure this is common, but I just don't think the snap rings will fit. I suppose I should look at them first!
Thanks again guys!
