Old 03-11-2004, 12:27 PM
Cobra Make, Engine: FFR#5015, 351 w/ carb
Default Which air filter set-up?
Trying to figure out what setup to run on my FFR replica. The engine is a 357 Windsor with Vic. Jr. Heads and intake. 700 dp Holley. I really like the look of the small air cleaner inside a turkey pan. I have heard this setup will choke my motor. Is their a K&N extreme lid (& drop base?) that would fit inside the turkey pan for normal driving, and then change to chrome top for shows? Hood clearence is a concern w/ the Vic Jr. intake. Pictures of different setups are appreciated!
Brian
FFR#5015 build in progress
351 w/Vic Jr. heads, Vic Jr. intake, Holley 700 DP, roller cam, tremmec, planned viper grey w/black stripes
Old 03-11-2004, 01:40 PM
Brian,
You could do some searches for Turkey Pan but I will tell you what some will reveal. So long as you use a low restriction filter element, some people have found little difference between cold air induction via Turkey pan, and big airfilter. One person tried several configs on his engine and the HP difference I believe was in the single digits.
Old 03-11-2004, 01:44 PM
Here was one thread
turkey pan
Cobra Make, Engine: B&B #281, 351w from The Engine Factory, and a Ford AOD from TCI
Check out this web site:
http://www.flamingengraving.com/
Old 03-11-2004, 04:07 PM
Thanks for the links guys. I wasnt trying to gain performance from the turkey pan, i like it for the looks and just didnt want to lose hp. I have heard that it could choke the motor. In my searches it looks like as long as you use a high flow filter there is very little difference. Seems i saw a K&N filter setup inside a turkey pan with an extreme lid, but cant find it now.
Brian
