Old 03-11-2004, 02:59 PM
CobraCurtis's Avatar
Cobra Make, Engine: stack injected 408W Factory Five roadster
Default stacked fuel injection vs. carbed
Hey guys help out a guy in search of answers. Besides the obvious price difference, what are the pros and cons of a stacked fuel injection system vs. a carbed setup? My application will be in a 351W with an estimated 425HP+.
CobraCurtis
Old 04-18-2004, 02:01 AM
Cobra Make, Engine: 302w EFI forged pistons x303 cam, trickflow inlet, roller rockers AFR heads. T56 6speed, 9inch LSD. DRB kit.
Default EFI
Hi, EFI setup is a bit more expensive but if you will be using the car as a sunday driver I feel EFI is a much better option as you can just turn the key and go. You dont spend two hours under the bonnet trying to tune it. You can just enjoy the ride. I have New trickflow inlet, 24 lb injectors etc, not too expensive.
Old 10-08-2004, 09:56 AM
look here at this site for your stack injection www.twminduction.com
Old 10-08-2004, 03:33 PM
cobra Curtis Curt there is a 15-30 hp advantage in the midrange depending on head work and cam shaft. FI is the way to go. After it is set up, it's like driving your family car, starts right up, get's just as good power as with a carb until 6500 rpm where a carb wins out. The emmissions and fuel stretching are the advantage. The stack setup looks cooler then the carb setup. Price is the only problem and running fuel lines both ways and where to put the electronics. I love my Speed pro setup works great. Rick Lake
Old 10-08-2004, 04:02 PM
DonC's Avatar
CobraCurtis:
Check www.verycoolparts.com run by Wayne Presley (my apologies if I spelled the last name wrong). He's got an IR Stack configuration and a lot of information on his site.
DonC
Old 10-08-2004, 04:09 PM
BMK's Avatar
BMK BMK is offline
CobraCurtis
Now this will confuse you..
Have a look at the 'Thread' and link titled 'Roush 402 Spec. sheet' in the Active Topics.
Damn that looks good..
Bernie
Bernie Knight
Old 10-08-2004, 04:12 PM
BMK's Avatar
BMK BMK is offline
Hey Rick Lake
Now dont be slack put some photos in your gallery...
"Red light George' stayed home I hear....
Bernie
Bernie Knight
Old 10-08-2004, 06:06 PM
I feel the need for speed
Default Hello Hank
I have the TWM induction set up on my 460 motor.... It is the best designed system around. I have pictures here on Club Cobra...I think they are under rdorman......
I would be happy to answer questions...
Old 10-09-2004, 06:03 AM
Bernie Knight They black flagged me for doing multi tasking when racing the car. No waving, no picture taken, and watch out for red lights. Gateway is getting tough. I asked Santa for a camera for christmas, we will see. Jay has some pictures on Super coupe at Run&Gun. I think he got he a couple of times. Parts coming in for new motor. almost ready. Want to see what the BT heads look like. A couple of people said they look so-so. I want to see KC's numbers on them. If I go this way I will not bore the new block out to 4.280. The heads have 2.19 valves, and a different chamber design. Looks high swirl, 64cc someone wrote. Got the dyno slim, still running numbers to see the best combo. I will let you know what I end up with. No 700hp, and no STORIES of 9.0's in the 1/4 mile. I got the paxton hood made for the car. May put the Paxton on just for fun. Have to bring the other hood for matchup on color. Should be nice when done. Linkage in shifter gave me a problem at R&G. Need stronger springs in the shifter to stop 2-5 gear shifters when racing and 4th to 1st gear spin outs in turn 1. Car was not HAPPY about that one, might make the Mag. Hope you are well, family too. Rick Lake
