Old 04-27-2004, 05:47 AM
Cobra Make, Engine: BRM #20, Ford 302, Holley 600dp
Send a message via ICQ to ridelikehell
Default I'm dumb...HELP!...heater/collant hoses!!!!
ok, the story is i ripped apart an old Ford 5.0 efi and converted it to carb...now being as stupid as i am, and considering the fact that i am using all new hoses and fittings on the new block...i neglected to label the hose locations and i was also stupid enough to inconviently throw all of the old stuff away...
so i've got 4 pics, and i've circled the holes where i don't know what does where...just to make things easier on myself, i'll include a small description with each on the site...
btw...I had to make a cardomain site for them because i'm computer illiterate and I have no clue how to post them here...
http://www.cardomain.com/id/heaterhoses
thanks in advance!!!! I know you all wont let me down!!!!
Old 04-27-2004, 08:21 AM
Cobra Make, Engine: Johnspeed,408W,Tremec 600 roadrace, Liquid Yellow w/Black stripes
Post
Hi Dave,
In your first picture, the 2 holes are a manifold vaccum sorce for things like the power brake booster. Use fittings and plugs from the hardware store, the plumbing section. Dont forget to use a sealant or Teflon tape. Try the local speed shop or the old mustang bone yard for the throttle return bracket. 2nd and 3rd pictures, the big opening/hose is for the upper radiator. Lower hose goes to the water pump. Assuming your going with a standard flow and not a reverse flow cooling system. The small hose next to that is the water pump by-pass hose. A small 90 degree hose 5-6 inches long. Get a preformed hose for that one. It connects the manifold to the water pump outlet, the one its right inline with. The hole in the intake manifold at the front that points up must be for the heater core return hose, mine is at the rear of the intake manifold but I didn't see one on the right rear of your manifold. The tempurature gauge sending unit should go into the front of the manifold on the other side of the distributor, intake at the left front. The other outlet on the water pump goes to the heater core inlet, maybe its labeled. I don't think it matters. If you are going to run a heater control valve put it in the inlet hose.
Hope this helps.
PS. Always reference to the right and left of the car as if your in the drivers seat.
Ted.
Old 04-27-2004, 11:15 AM
thats excellent thanks very much!
just one quick thing i'm still unclear on...the only vacuum line i'm running is to the brake booster, so do i just take my pick of which hole to use for that, and plug the other one?
thanks again!
Old 04-27-2004, 05:55 PM
Thumbs up
Hi Dave,
You got it. But I would use the one closer to the carb, and plug the one on the intake runner. Glad I could help.
Ted.
