November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-17-2004, 12:22 AM
Cobra Make, Engine: SPF124 MKIII Sport. FR351W-380HP w/TremecT5
Send a message via Yahoo to baypally208
Default Carb for a 385hp Ford Crate Engine?
Engine: Ford Motorsport 351W 385HP
Carb: Rebuilt 750 Holley with Vacuum Secondaries
Problems:
- We keep getting misfires under load (during accelleration) with
3/4 throttle between 3500 and 5000 RPM.
- Minor Backfiring.
- We've been playing around with it but can't get consistant
accelleration.
We've Checked:
Timing Good
Distributor Replaced
Plugs and Wires Replaced
Premium Grade Fuel
Any recommendations?
- The Drewster
Old 06-17-2004, 04:42 AM
mrmustang's Avatar
Gold Star Contributor
Dump the carb........You need no more than a 650dp Holley (#04777C), Moroso 1:1 secondary linkage kit, and some dyno tuning time.........I should know, I went through 6 carbs on my last 351W/385hp Ford crate engine before finding someone with a chassis dyno.............After two hours on the dyno with the new carb, it was running at peak performance and efficency............
Bill S.
Old 06-17-2004, 09:28 AM
Default Hey Bill....
No way to use the 750, huh?
What's the jetting and shots on the 650 you're using?
Thanks!
-Drew
- The Drewster
Old 06-17-2004, 04:41 PM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Guys, not that I know much but.......
Cubic Feet Per Minute Needed Formula:
CID * max rpm / 3456 = CFM needed
Example:
302 * 5500 = 1,661,000 (divided by) / 3456 = 480.6 CFM
One of those things I could never get out of my head.....
I'm not busy because I did it right the third time . . .I think!
Old 06-19-2004, 05:27 AM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
Sounds like you are running lean. Look at the plugs to confirm and try upping the jets. That cam really needs a DP though. I run the recommended carb for that motor - model 9379 with 68 / 81 jets. The motor has bigger heads though - AFR 185
Old 06-19-2004, 10:56 AM
mrmustang's Avatar
Default Re: Hey Bill....
Shots were not changed, jets according to my notes are 72/68's with the Moroso 1:1 linkage kit and the choke horn milled off......
Bill S.
Thanks!
-Drew
Old 06-19-2004, 04:33 PM
Cobra Make, Engine: Superformance #1374 with 392 RDI Stroker
Had a buddy with the exact engine and problem. Changed to a Holley 650 and problem went away. 750 to much.
Just my 2 cents
