January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 06-19-2004, 03:50 PM
Cobra Make, Engine: Shell Valley, 302
Unhappy 302 engine problems
I have a Ford 302 carburated engine in my toy. Recently it seems to have developed a problem.
It seems to be breaking up really bad, especially at higher RPM's. When I pull up to a stop sign, it does not initially want to idle. After giving a little gas for a few seconds, it seems to settle down and be fine.
I was just out for a ride and it was really bad for about 20 minutes. The last 20 minutes of the ride, it did not seem to break up as bad as at the beginning.
Any suggestions?
Thanks,
Kevin
Old 06-19-2004, 06:09 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
It sounds like a carb problem--If it is Holley carb it will be a love/hate relation. I recently dumped my Holley and replaced it with a Edlebrock 1405. I experienced some of the same symptoms you described with my 289 Hi-PO running a Holley.
Good Luck
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 06-19-2004, 06:21 PM
G.R.'s Avatar
If it is a Holley it could be jets, accelerator pump springs, float levels, sticking choke if so equipped, vacuum leak, weak fuel pump delivery pressure, clogged/hampered air cleaner element(the oval Cobra style aren't all that good for air delivery) and a myriad of other ailments.
Can you tell I'm not enamored with the vaunted Holley I spent close to $150 on rebuild kits, jets, etc. on my Holley--I put the Edlebrock on changed one set of metering rods and my car has never run better.
Old 06-20-2004, 05:10 AM
Bonos's Avatar
Club Cobra Member
Cobra Make, Engine: 1967 E-M with 302 Ford
Kevin ,
Before you get rid of that holley . Try adjusting the carb with a vacumn gage so as to get the most vacumn at idle and then recheck and adjust vacumn at 2800 rpm's.
*** Make sure your timing is set before carb ajust***
bonos
Old 06-28-2004, 01:58 PM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
check the fuel filter?
Old 06-28-2004, 04:33 PM
Cobra Make, Engine: Venom 351W
Send a message via AIM to joeg
Also check your floats. One may be sticking slightly open. Had same problem as you, it was a stuck float.
joeg
Old 06-30-2004, 07:22 AM
TonyMadrid's Avatar
Cobra Make, Engine: A&C 351W, C4
Default 302 problem
One thing I have learned is that when most people perceive their problem to immediately be a carb problem, it usually is not. In most cases the problem is a vacuum problem.
Before turning to the carb as the source of the problem, first make sure that you don't have any vacuum leaks.
Old 06-30-2004, 10:07 AM
Cobra Make, Engine: ERA 289 FIA #2086, 302/320 HP, Dart heads, hydraulic
Kevin,
I would start with the easy things:
1) check the float levels, make sure they aren't leaking.
2) PCV value - could be stuck open
3) Power valve too high, or blown, use 1/2 of idle vacuum.
4) If it only occurs under hard accel/braking consider jet extensions.
5) Clean the metering blocks
Holley QC is down the tubes - had a repeated stuck secondary float until I replaced the needle valve.
Old 07-04-2004, 04:18 AM
Cobra Make, Engine: workin on it
not knowing your engine, whats your compression? maybe ur not using a high enough octane? 10:1 or higher i would be using at least 93 oct.
Old 07-04-2004, 04:47 AM
mrmustang's Avatar
Gold Star Contributor
Have you read the plugs yet??? If so, what did you find?? if not, then this is the first place I would start, as the plugs will tell you if your running too rich or too learn............
Bill S.
Old 07-04-2004, 06:50 AM
PatBuckley's Avatar
G.R.
Wasn't your carb base not true?
Pat
Old 07-04-2004, 10:43 AM
I appreciate all of the input. I put a new distributor cap and rotor on and it seems to be running fine. I've been out for 3 test runs in the past 2 days...so far so good.
Thanks again,
KC
Old 07-04-2004, 08:39 PM
G.R.'s Avatar
Originally posted by PatBuckley
G.R.
Pat
Pat the throttle body was warped, front to back and diagonally, evidently causing a vacuum leak even with double gaskets after the engine was warmed up at speed. The warpage was not visable to the eye or real noticable on a flat surface.
