| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
08-07-2004, 12:09 AM
He
Cobra Make, Engine: Actual car: AC Autokraft MK IV with Keith Craft 331. Gone: Home built Crendon, original style twin tube frame, powder coated, stainless sidepipes. FE 433
Distributor gear destroyd, Help!!
Hello all,
during a test run on the freeway yesterday, my 351C stopped working apruptly.
After a short system check I found a badly worn distributor gear, teeth thin as knifes and 30% of them gone completely.
The engine was completely rebuild with all new parts.
Distributor is(was) Mallory dual point.
Cam is:
Crane Camshaft Specification Card
Part Number: 524421
Grind Number: H-288-2 (REPLACES CCH-288-2)
LIFT: INTAKE @CAM 305 @VALVE 528 ROCKER ARM RATIO
EXHAUST @CAM 3101 @VALVE 536 1.73
ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER ARM RATIOS
CAM TIMING OPENS CLOSES ADV DURATION
@ .004 INTAKE 33 BTDC 75 ABDC 288 °
TAPPET LIFT EXHAUST 75 BBDC 37 ATDC 292 °
CAM TIMING OPENS CLOSES MAX LIFT DURATION
@ .050 INTAKE 8 BTDC 38 ABDC 105 °ATDC 226 °
TAPPET LIFT EXHAUST 50 BBDC 0 ATDC 115 °BTDC 230 °
Rest:
Block: 351 CJ, 4Bolt main bearings
Crank: Steel, Test Mark 4MA. Grinded, polished, nitrided
Rods: Eagle H-Beam, forged
Pistons: Speedpro, forged, coated sides, floating bolts
Heads: 2V with open chamber, reworked, volumes equalized, spring hight adjusted to max 0.1mm difference.
Springs: Comp Cams Double Springs
Pusrods: Manley Moly Rods
Rocker Arms: Scorpion Aluminium Roller
Valves: Manley
Bolts internal: All ARP, Comp Series, rods for the heads and mains
Bolts external: All ARP, Comp Series, Stainless 12Point
Intake: Edelbrock
Valve Covers: Shelby Script und LOGO
Carb: Holley 4V, 850
Oilpan: 351 CJ, production w. buffles and welded windage tray
Oilpump: Melling HV, HD modified to be adjustable
Oilpump drive shaft: ARP
Distributor: Orig. Mallory Dual point
Sparkplug wires: Taylor Blue, 8mm, Silicon Plugs, Angled
Waterpump: Edelbrock HV, Alu
Starter: Orig. Ford High Torque
Has anybody an idea what happend???
Sitting on the freeway/autobahn I replaced my died Mallory by an stock ford 351c distributor which followed the mallory in the same way 4o miles later.
This never happend to me driving american v8s the last 15 Years.
Heeeeelp!!!!!!
Cheers from Germany,
Uwe
Everything should be as simple as possible - but not simpler !!
08-07-2004, 04:14 AM
Seasoned Member
VA
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
Uwe;
That is usually caused by running a steel roller cam with a iron dist. gear. Suggest you replace your dist. gear with either a bronze, steel, or polymer(Comp Cams) gear.
Bill Stradtner
08-07-2004, 04:34 AM
FL
Yo Uwe,
Sorry to hear of your problem - my sincerest condolences
Been there, done that:
Threads on distributor gear problems
I ended up with a Crane steel cam using hydraulic roller tappets, and a Crane steel distributor gear carefully located on the shaft to the 4.000" spec. After 9,000+ miles no visible wear when I pull the distributor.
Bottom line: you must use compatible cam & gear materials. Steel/steel or cast/cast.
You can also use a bronze distributor gear but it then becomes a maintenance item with a life of 5,000 miles or so. OK for drag racing but not for street miles.
Carefully assemble the drive gear onto the distributor shaft maintaining the four inch distance
Alas, I fear you may have destroyed the cam, as I did, necessitating its replacement as well  I conclude this after seeing that you found the second distributor gear worn out suddenly as well.
I feel your pain: Ford reimbursed nothing (zero zip nada) even though they installed my gear wrong - I'm out the $2800 parts & labor to correct their mistake.
I hope my diagnosis is incorrect!
Let us know,
Tom
08-07-2004, 04:38 AM
Oh
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Wrong gears is the answer, but you'll also have to pull the engine and have everything hot tanked to get rid of the metal shavings and new bearings put in
Jack
XSSIVE .....
08-07-2004, 05:50 AM
Charter Club Cobra Member
OR
Cobra Make, Engine: My Shell Valley Coupe is here! Now the building begins....
This is most likely your problem,
HV oil pumps on a small block Ford are really hard on distributor gears, on new engines they are even worse.
Scott S
Working as hard as I can every day to double my carbon footprint.
08-07-2004, 10:50 AM
He
Dear all,
thanks for the kind answers. I posted the same in "all cobra talk" and left there the following in additional:
"PS: I forgot one point maybe the most important: Pressure at oil pump is set to 114 PSI. We did the same thing with Buick and Chevy engines and nothing happend.
Is the distributor gear for Ford from such a weak material that it can not withstand the higher load comming from my oilpump?
Are there better distributor gears for high performance use available?
My one was made from steel.
Uwe
Wilf,
the cam is a crane hydraulik part nr. 524421.
No roller.
I'm using 5W40 Oil, shouldn't be a problem.
I will partly disassemble the engine, clean the sump, check the cam gear and oil pump.
The pressure will be readjusted to 80-85 PSI cold and 70-75 PSI warm.
The only thing I'm looking for is a better Distributor gear. Made from Steel instead of Iron??? There are steel gears availlable from Crane for my distributor.
Mine was Iron, not Steel as I posted before.
O.K. so far???
What Crane says about my cam is:
FAIR IDLE, MODERATE PERFORMANCE USAGE, GOOD MID-RANGE HP, BRACKET RACING, AUTO TRANS W/2500+ CONVERTER, 3200-3600 CRUISE RPM, 9.5 TO 11.0 COMPRESSION RATIO ADVISED. BASIC RPM 2500-5500
Thanks for helping an completely frustrated(at the moment) Cleveland driver.
Uwe
Rick and Perry Henry,
we pushed the pressure up because our engines are made to go 7000 revs and more. We tried to be on the "safe side".
No problem so far with chevys and buicks.
Because of the cleveland oiling problems we decided to go the same way, but we learned.................
I'm going to heed your statements, the pressure will be droped to 70-75 warm.
Sorry for my bad english writing
Thanks all,
Uwe"
Sorry for my late response, I was a little bit frustrated yesterday and tried to get as much as possible answers.
A well motivated,
Uwe
08-07-2004, 01:53 PM
UK
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Uwe - with that cam, a steel gear should be OK, but check with the cam and the distributor manufacturer helplines.
I still think that the high oil pressure you set is the root of the problem. It multiplies the torque that the gear must transmit.
Be happy - you are the first Cleveland owner here that I know of with this problem! You are therefore unique. Have you tried the Cleveland engine forum at http://www.network54.com/Hide/Forum/119419?it=0
( don't get me wrong - I am very sympathetic to how you must be feeling right now, but it IS part and parcel of Cobra ownership).
Wilf
08-07-2004, 03:32 PM
FL
Yo Uwe,
also
in reference to the distributor gear.
I couldn't find the cam material on the Crane site. I ASSUME the hydraulic flat tappet cam is cast iron and therefore it sounds as if you have the correct distributor gear material. You'd need to check with Crane directly to confirm the materials.
Unfortunately this points to other causes such as the high output oil pump or the positon of the gear on the distributor shaft (or both!) as possible culprits.
Let us know how you proceed.
Tom
08-08-2004, 12:41 PM
FL
Cobra Make, Engine: ERA 427SC FMS 351W
I don't want to worry about gear metals...
I have a FMS 351W crate engine (M-6007-A351). It is rated at 385HP. The cam is a hydraulic (M-6250-A351) with roller rocker arms. I do not believe the cam is a “roller cam”.
I replaced the Duraspark distributor with a 8478 small diameter MSD distributor about a year ago but have not driven too many miles. I did not pay any attention to type of metal used for the cam distributor gear or on the new distributor. Does anyone know what type of metal (iron, hardened iron, etc.) the cam distributor gear on the cam is? What type of metal is the standard gear on the 8478 MSD?
I really do not understand the compatibility of these two metal gears. I believe I am hearing from the forums that an iron or hardened iron “roller” cam needs to be mated to a steel gear on the distributor. Does this recommendation change if your cam is not a “roller”?
08-08-2004, 03:52 PM
FL
Hi Cobra 29,
I agree I wasn't totally clear about this, so here goes again
Roller cams are almost always steel cams, either solid or hydraulic roller lifters are used.
Flat tappet cams (either solid or hydraulic flat tappet cams) are non-roller lifter cams made of cast iron.
For the distributor gear, use a steel gear with a steel cam, a cast iron gear with a cast iron cam.
A bronze gear may be used with either cam (it's made of softer metal than either of these) but must be checked every few thousand miles for wear, as it will not last anywhere near as long as the steel or iron gears.
Hope this clears that up
The cam mfr can tell you what material your cam is made of and most can sell you the appropriate material gear for the distributor.
Tom
08-08-2004, 04:56 PM
30 Year Wait is Over
ONT
Cobra Make, Engine: SPF 1630 '70 429 SCJ / 501
I am using the Crane steel hydraulic roller cam and the Crane steel distributor gear. Someone posted and said they were developed for the Busch series engines. Works great and no "bronze" problems.
http://www.cranecams.com/index.php?s...&lvl=3&prt=113
The Butcher of Cobra Lads fame documented his problems with the distributor gear installation and offered some good tips.
http://www.cobralads.com/butcher62.html
David J. Seed
Q: What makes a good racer?
A: Size 14 shoe, size 2 hat.
Buddy Baker, NASCAR Hero
08-25-2004, 08:43 AM
Distributor gear applications are:
hydraulic roller cam - steel
solid roller - bronze or polymer
flat tappet(hydraulic or solid) - cast iron
First of all check the bottom of the distributor gear and see if you have any wear. There is a deck surface with a guide hole in it inside the block. You can see it using a flashlight with the distributor removed. I have seen a few distributors with the gear installed to low on the distridutor shaft. This results in binding the distributor gear against this deck surface when you tighten down the distributor hold down. End result is chewed up distributor gear and in worst case the cam gear will be worn. If you put in a new distributor gear with a worn cam gear it will just cause spark scatter and also the gear will wear out faster the next time. Make sure you change the oil also. Good luck.
Jeff
08-31-2004, 12:36 AM
He
O.K. so far....short update:
Engine is pulled and all bearings are checked!!
Everything O.K. so far...... the block will be cleaned afterwards.
We are going to replace the cam and set up the oil pump to 75 PSI cold.
Uwe
08-31-2004, 09:59 AM
FL
Cobra Make, Engine: no cobra, 71 Rx2 460windsor
Alot of your problem was probably the 114psi. Rule of thumb is 10psi for every 1000 rpm. Unless you have stroked your motor beyond belief or turning it 11,000rpms you shouldnt need that much psi. If your motor is fairly new and your not using a remote filter or cooler a standard pump at 70psi will be more then you need. A high volume pump is probably not needed in your case, its just creating heat and robbing horsepower.
check this site out
http://www.melling.com/support/bulletins/view.asp?id=12
09-03-2004, 06:49 AM
He
Forgot one thing:
Oil cooler is installed of course.
Uwe
09-03-2004, 07:03 AM
Renegade Nuns on Wheels
Oh
Sorry to hear about your troubles! I am going to go home and pull my mallory and check it.
We basically have the same engine and I have concidered running the cam that you have. How do you like the cam? Have you had it dyno'd? What are the valve releifs in the pistons and what kind of valve clearence did you end up with? Is it installed straight up or.............?
Thanks
Rick
Oh, by the way, a good hardened steel pin should be used and adding a second never hurt a thing.
09-03-2004, 10:19 AM
He
Rick,
I like the cam because of its low cruising rpm, idle is a bit rough, but i like it that way.
The 2V and 4V open chamber heads have been the only heads available here in Germany. Therefore i choosed to install the 2Vs because of their better bottem end torque.
Engine is very quick from 2000 up to 6000 rpm. Nice.
To increase the low compression comming with a stock open chamber set up we decided to install the speedpro pistons with valve reliefs. Result is a compression ratio from about 11:1.
Valve clearence is on the safe side but i don't have the figures in mind right now. Let me check my notes.
All valve spring seats are machined and shimmed to get the same compressed spring hight, +/- 1/10th of a millimeter tolerance.
The rockers are scorpion rollers with 1:1.7 ratio
I think You don't have to be afraid as long as "The Butchers" hints are followed.
The gear problem was caused by my high oil pressure setting. It was not 114 as i wrote before, it was up to 140 PSI cold!!!
So check your distributor gear with the butchers instructions in hand and don't worry.
If somebody would be interested maybe I would start something like a cobra build-up report pictured more or less completely.
Uwe
09-03-2004, 10:38 AM
Oh
Thanks for the information. I now have about 12,000 on my Cleveland. Run 5W-30 Mobil one in it year round. Hot pressure it 30+-, Cold is 80+ at fast idle. I think the pressure relief is around 80 or 90. Plenty of pressure. Picks up 8 or 9 pounds per thousand. I took a main cap and rod cap of a while back, bearing look like new.
Ready for Oktoberfest? We have a big Oktoberfest party this Saturday!
Rick
09-10-2004, 04:45 AM
He
I'm getting nuts.
Engine is right back in the car with new cam, new distributor gear. Distributor length is measured it's not binding in the bottom.
Everthing looked O.K.
Pressure relief was set to 90PSI cold.
Car has now 90PSI cold, 75-80 PSI warm at 2000 rpm.
But......................95-100 PSI warm at 3000 to 3500 rpm.
100 PSI is the max even with 6000 rpm on the meter.
I think it's the HV Oil pump which is setting the 20 PSI higher end result warm.
Oil is 5W30 synthetic. Oil filter is a Moroso racing with very low flow resistance.
Should we open again the oil pan and decrease the warm pressure at 3000 rpm to 70 PSI????
Oil pump is still adjustable.
Uwe
09-10-2004, 08:30 AM
UK
Personally, I would set the pressure relief to 80 psi to avoid a repeat performance of your previous problems.
It looks as tho' it is set at 100 psi now, and as the revs pick up and the pump generates more pressure, that is what you are seeing.
Wilf
