November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 12-26-2004, 08:09 PM
Cobra Make, Engine: Lonestar / 408W Stroker
Default Heads, Iron or Alum?
1969 408 Windsor Strocker Should I go Alum or Iron heads?
HMIHNTR
Lone Star LSC427, Speed-o-Motive 408 Stroker
2005 Ford SD 6.0 Harley Davidson /Super Chip 425 HP
1975 24' Campbell V-Drive / 1963 427 Ford
2000 Prowler 32' 5th wheel
And the Harley pulls them both to Lake Havasu
Old 12-27-2004, 04:00 AM
Cobra Make, Engine: Classic Roadsters, 393 stroker, Tremec 3550, about 425 hp, MDA GT40 289
Roy,
I've got a 393W stroker and I'm running the Roush 200 iron heads. They've been pocket ported and the motor runs very strong. I'm a bit of an old schooler where I believe that I like the durability and stroutness of iron over aluminum. I guess I've always felt that aluminum is more fragile. Heck, I don't know, the aluminum heads look nicer though.
To each his own.
Jim
Man, it would've been helpful to know that cop was behind me a minute ago!
Old 12-27-2004, 05:31 AM
Ron61's Avatar
Post
Rou,
I run a 416 stroker with the Trick Flow twisted wedge aluminum heads. All ported and polished. Main thing I noticed over the iron heads on my big block is loss of weight and heat dissipation is much better letting me run Calif. pump gas in a 11:1 compression engine as long as I don't really get on it hard. The big block with the iron heads is also 11:1, and I have to run it a lot easier to keep from hearing that dreadful pinging of the valves. Retarding timing helps, but in 116 degree, humid weather, it is still a problem. But for just driving I really have no bad problems with either of them on pump gas.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 12-27-2004, 06:22 AM
Big-Foot's Avatar
Cobra Make, Engine: RCR GT40 #45
Roy - The aluminum head will dissapate heat quicker than will the iron head. It will also let you get away with a little more compression on today's pump gas - although Ron Widener here has found out, you really can't get away with a lot. With aluminum heads we typically will set the maximum pump gas compression at 10.5:1 for a "Sunday Competition" engine, and then 10:1 on cars that will rarely see the track.
Your engine would really like a set of AFR185 heads. The ports are not so huge that you loose the all important velocity for docile street driving.
Regards - Randy
RCR40 #45 http://www.GT-Forty.com
Old 01-02-2005, 06:20 PM
Cobra Make, Engine: 68 GT 500 convt, 428 Cobra Jet
Red face Iron vs Aluminum
Hey;
I looked into that ? long and hard. Weight advantage or custom and cool control. I got a 347 stroker for my 65 and finally narrowed it down to Roush 200.
Good Luck
