03-08-2005, 07:13 PM
Seasoned Member
VA
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
Brainsboy;
I've never done this myself, but I HEARD that if you swap your secondary wires to the coil it will start, run, and lose spark at higher RPM's.
Bill Stradtner
03-08-2005, 07:16 PM
Cobra Make, Engine: no cobra, 71 Rx2 460windsor
Ill check it
03-09-2005, 01:37 PM
TR
Cobra Make, Engine: 67 Mustang with Eleanor body kit.408w+250hp NOS with alcohol
Which kind of fuel pump are using now?
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
http://www.clubcobra.com/photopost/s...at=500&thumb=1
http://www.motorspor.com/index.cfm?f...r&haber_id=250
http://fordboss.blogcu.com/1967-must...leanor/5605130
http://www.auto-drom.com/haber-trtuning.htm
http://www.motorspor.com/index.cfm?f...&haber_id=1897
03-09-2005, 03:09 PM
Im using a holley Fuel pump 6psi at idle.
03-10-2005, 09:00 AM
6th Generation Texan
Have you adjusted the valves yet and noticed any difference ?
03-10-2005, 09:20 AM
Or
Cobra Make, Engine: shell valley
Had the same problem wouldn't pull past 6K only spent a grand to find out the air cleaner to small.
Ken
Talent is your head in communication with your balls.
03-10-2005, 12:50 PM
TR
Mechanical or electric fuel pump?
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
03-10-2005, 01:32 PM
Electric Fuel pump. The air cleaner is a Holley bee hive style. I was going to adjust them but it got into the 40's last night. I'll probably do it tonight
03-11-2005, 07:39 AM
Well I adjusted the valves last night. Set everything to 1/2 turn, took my time and got it right on the money. I started the motor, it really didnt sound as good, but I guess it just may be the design of my exhaust system, so I decieded to try it anyhow.
I set the tach to 5,500 and made 2 passes down my road. I got going about 25mph kept the car in second gear and hit the gas. Before I had time to say "jumpin leap frogs", the shift light came on, and I looked down at a 6000rpm. Turned around and did the same thing this time I pulled a nice 6200rpm.
Thanks for all the suggestions and help. I still have a big lag in the secondarys when they kick in, so I may try a new carb anyhow and see if I can pull up to 6500.
Thanks again everyone
Ben
03-11-2005, 10:06 AM
Cobra Make, Engine: Superformance #1374 with 392 RDI Stroker
Ben, glad you got that worked out. Now you just have to get the carb right.
That's what's good about this site is everyone offers great advise for solving problems
Mark
03-11-2005, 04:10 PM
That sure is great news.Glad it worked out for you.
This website is nothing short of amazing.
It has helped me any number of times.
03-27-2005, 09:42 AM
Cobra Make, Engine: rdi 408w
I have a RDI alum 408 and it was doing the same thing and ive done every everyone here has said and nothing worked!! So I went to the dyno and found out my motor likes 38deg. of timming,I had only 28deg. now my 408 pulls to 6250rpm with no prob.
STACY TRAN
