Old 05-14-2005, 09:18 AM
Default camshaft replacement
Can anyone tell me how to remove a camshaft from a 302?
1989 GT w/ a few mods
Old 05-14-2005, 09:42 AM
You're gonna have to give more info than that.....is it carbureted, fuel injected? Is the engine 100% assembled?
Old 05-14-2005, 10:18 AM
it's for a carb and it's pretty much assembled. It's missing the lower intake manifold carb and oil pan and missing the other front engine components like water pump, timing cover, and distributor..oh and it's missing the oil pump
Old 05-14-2005, 11:00 AM
You just wanting to pull it out?
Take the valve covers off, unbolt the rocker arms and twist them out of the way enough that you can pull the pushrods out.
Pull the lifters out of the lifter galley.
Unbolt the cam retainer plate on the front of the block.
Put a long bolt in the front of the cam to use as a handle....pull it out slowly....have someone else help you....don't let the cam bounce up and down as you pull it out, or you'll nick the cam bearings. Be easy.
BTW....carb'd engines don't have upper and lower intakes like fuel injected engines do.....
Old 05-15-2005, 07:09 AM
where exactly do i put a bolt infront of the cam?
Old 05-15-2005, 09:51 AM
Have you got the timing chain off? If not, you need to remove it also....when you pop the cam gear off, you'll see the hole you need....there will be a dowel right next to it. To get the timing chain off, take the bolt out of the cam first.....then "walk" the gear off the dowel....you can leave the crank gear on for now.
