05-03-2006, 07:03 AM
Ks
Cobra Make, Engine: B&B
ground clearance oil pans & bell housing
I'm sure this has been discussed but I can't find the thread.
What oil pan offers the best ground clearance on a 351w? I have the traditional dual sump, and I have a lakewood bell housing. I did see a superformance that the guy took some sort of a saw and lopped off the bottom of the flange to create some clearance.
I'd like to bring the car down a little bit but I'm already dealing with only about 2 inches of clearance.
Any suggestions greatly appreciated
Terry
05-03-2006, 07:06 AM
NJ
I'm using the Milodon Cobra Road Race pan.
Roscoe
05-03-2006, 07:23 AM
az
Depending on how much you want to spend, Armando's Racing Oil Pans have a fairly low clearance. He worked for Aviad for years. I'm very happy with mine on a big block. (about 400.00)
double ugly
05-03-2006, 08:34 AM
My Milodon sits pretty low also. I't makes me a little uncomfortable. Dry sump would seem the way to go if one had the bucks to spend.
Hyde D. Baker
05-03-2006, 10:19 AM
Cobra Make, Engine: Superformance 427 S/C 351W stroked to 396, by Southern Automotive
I have a Sperformance (for sale check the Cobras for sale) with 351 W and a Lakewood bellhousing. The car sits lower than normal and I modified the bellhousing. I first aligned all the bottom bolts so their flat sides were parallel to the ground, then I took a air cutoff wheel (please wear safety goggles) and cut off the bottom lip of the bellhousing even with the bottom bolts. As for the oil pan, I am running a Canton pan, but my pan lies a little back from the center of the front wheels so that when I go over a speed bump the front tires lift everything up. This OK for speed bumps, but for road gators (truck retreads on the road) or the man hole covers, its slow down, or say a quick prayer.
05-03-2006, 11:05 AM
OR
I've looked at the Canton road race pan and it has the same depth as the stock 351W pan- 8". In my car it will be below the rails by about 3/4" when I get done, I hope.
05-03-2006, 11:08 AM
On my FFR I am using an oil pan designed by Gordon Levy. It is a road race style holding 8 qts. The pan sits 1/4 inch above the bottom of the main rails.
As I'm changing oil tonight I can measure the pan from the block to the bottom if you wish.
05-03-2006, 03:45 PM
Ks
The mildon looks better than a stock pan, I'm terrified of getting stuck having to cross a speed bump someday.
I'd like to take a look at the Gordon Levy pan, if you could measure I'd really appreciate it!
On the bell housing, after it was cut, did it leave a gap, or would a gap be a problem? I guess I could leave a short lip along the bottom if anything.
05-03-2006, 03:49 PM
I really like the looks of the Aviaid pans. If I somehow destroy mine I'd probably go that direction.
Hyde D. Baker
05-03-2006, 05:26 PM
NJ
Cobra Make, Engine: Backdraft 408ci
I had a crossmember fabricated for mine that is attached to the lower frame rail. It hangs about a 1/2 inch lower than the bottom of the canton pan. Wouldn't want to hit the crossmember, but if I did I would be glad it was that and not the pan. Let's see if I can attach a picture below
05-03-2006, 06:15 PM
Northwood...
The pan is 7 1/2" at it's deepest point.
05-03-2006, 08:13 PM
Cobra Make, Engine: Johnspeed, 408w, TKO600
northwood,
Moroso 351w cobra kit car roadrace oil pan #20501 from jegs. Same a depth as a factory pan, holds 9qts. $235.99. Oil pick up #071024507 $57.99. Hope this helps.
Ted
05-03-2006, 08:17 PM
Ks
Mike, thanks for the measurement on the pan, what I need to do is measure the stock pan and see how much I can gain, or,,, buy a set of SUV tires and wheels for the car!
Nice idea on the crossmember, definitely won't crater the pan with that! Is the crossmember built like that for stability or protection of the pan?
05-03-2006, 08:25 PM
Ks
Roscoe,
may be a silly question but what are those lines going to your tremec for? Or does the photo just make it look like they're attached
05-04-2006, 05:32 AM
NJ
Those are the lines for the hydraulic throwout bearing coming out of the bell housing and draped over the trans. The ends you see are for the reservoir and the bleeder.
Roscoe
05-04-2006, 07:21 AM
Ks
Got it, thanks, I didn't use hydraulic, wasn't familiar with the parts, now I that I'm done I wish I had.
05-04-2006, 07:49 AM
NJ
Roscoe, at what point during the engine build do you add the fertilizer?
 Snakebit
05-04-2006, 07:54 AM
Ks
Fertilizer got added to my project right when I thought I'd build this thing within my budget
05-04-2006, 08:12 AM
NJ
Damn, I just went out and bought a new bag of fertilizer. That bag in the pic should be in the garage somewhere....hmmmm.....have to go look for it.....
Roscoe
Roscoe
05-04-2006, 10:05 AM
Ga.
Check my pics, I built in a little replaceable insurance.....teflon.......
Perry
