Old 06-06-2006, 09:25 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
Default oil coolers
How much will an oil cooler reduce the engine temp ? I have a 289 size radiator for a 402 FI monster motor. Hope i wont have to change the rad and fan set up.
the older i get the faster i was.
Old 06-06-2006, 09:44 AM
Hmmm....my first thought is that you might be looking at this wrong.
Use a radiator to cool your Water
Use an Oil Cooler to cool your Oil.
For me, the 2 temps can vary drastically from each other. I use a manual by-pass valve which allows me to turn the oil cooler on or off. I find that during general driving, even without the oil cooler, my oil tends to run a bit colder than I would like....but my water is fine. While driving sporty with high engine revs, My oil will quickly race up from about 170F to 240F without the cooler....and again the water temp stays in the normal range.
The point is that in my opiniom, it might be possible to have Dangerously high oil temps with very cold water temps...and visa versa.
So if your radiator cooling capacity is too low...you need a bigger radiator...not more oil cooling. This way you don't make icy cold oil while trying to compensate for excessively hot water.
Just my thoughts..
Have fun!!
-Rob
Old 06-06-2006, 11:15 AM
*13*'s Avatar
If you have the set up supplied by B&B & they suggest it will work then check all obvious things before you give them a call for experienced advise. Timing, Thermostat rating, carb jetting, correct rotation water pump & volume, good coolant flow & so on...
ERA FIA 2088
Old 06-08-2006, 08:55 AM
pmfranke's Avatar
thanks for the comments.the next couple of weeks will tell . I 'll fire it up for the first time and find out how much money it will take to fix what i have done.
