08-08-2006, 06:18 AM
IL
Cobra Make, Engine: SPO 1850, 392 stroker
Oil Change on a FMS 392
How many quarts of oil does a your standard crate FMS 392 w/ oil cooler and remote filter require?
I am planning on using a 10w-30.
Anything else special I should know?
TIA,
Bignoze
08-08-2006, 06:48 AM
6th Generation Texan
Mine took 8 qts... with the stock pan that came with it.
08-08-2006, 06:56 AM
IL
I am going to assume thats with the filter?
08-08-2006, 07:00 AM
Yes,that is with 1 filter.
09-02-2006, 11:20 AM
IL
so riddle me this, why did the car only take like 5 qts? And I am sure I have an FMS 392. I put like 7 in plus filled the filter and when I checked the oil it was way over? So i had to drain some out like 2.5 qts to be at the fill line. Did I not empty the pan right and is there any other place I should have drained besides the pan and the remote filter? The pan had 2 drain plugs. I looked at the FMS website and its says its a 7qt pan. Is there a place to drain the Oil Cooler?
TIA,
09-02-2006, 12:15 PM
Fl
Cobra Make, Engine: BDR # 165 392 Ford Crate 430HP
bignoze, the standard oil pan that mine came with takes 5 qts with filter, double hump pan.
Like a kid in the candy store I just can't get enough
Current rides GT500 & Backdraft
09-02-2006, 01:01 PM
IL
yes it does have the double hump, so I guess it is a 5qt thanks for the info.
