| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
11-17-2006, 08:24 AM
ID
Cobra Make, Engine: Hurricane Motosports
Best heads for 408
Looking for best performance heads for a 408. The exhaust ports have to be for stock headers. I will be using full roller valve trane. Looking around the 205 range and want to run on pump gas. Thanks Bermblaster
11-17-2006, 10:31 AM
NV
Cobra Make, Engine: Classic Roadster; 351W
You did not state cam specs or anticipated HP / TQ levels. However, the AFR 205's work well on these strokers. Do some searches.
11-17-2006, 11:11 AM
PA
How about the 303's?
11-17-2006, 11:13 AM
OR
Edelbrock Vic. Jr., Canfields, AFR 205's, Trick Flow, etc....
Seems to me there was a head comparison posted just last week on this board with charts, graphs, etc... might want to do a search.
11-17-2006, 11:15 AM
ID
Always want max hp I plan on having duration in the upper 250 @.050 Have not decided on exact cam specs. I have comp cams 292h in my mustang 351. I want more. The bottom end [408] will be scat products [forged]. I want the car to sound as bad as it looks.
11-17-2006, 11:18 AM
ID
Does any one know if the AFR 205s are available in the stock exhaust port height? Bermblaster
11-17-2006, 12:18 PM
IL
I would suggest the Brodix Track 1 M2 CNC'ed head from Keith Craft. It will flow more than the AFR's. I would look for heads that flow over 300cfm at .500 lift as a starting point. The Brodix are around 312 at .500 and the Yates are around 360 cfm.
High Maintenance Racing Team
Run & Gun 2003 - 2013
11-17-2006, 12:40 PM
NC
Cobra Make, Engine: Hurricane #HM1024, 418 Stroker, TKO 600
Hey Berm,
I don't think your gonna find too many aftermarket heads that don't have raised exhaust ports. Seems like most of them that I've looked at are raised varying amounts. A lot of them are in the .130-.135 range. Most raised ports shouldn't be a problem with the Hurricane. I'm using Dart heads (exhaust raised .135) and don't have any issues. I think Ryan has Victor Jr's and they're not a problem. I think as long as you choose something thats gonna work with the rest of your combination you'll be OK.
Mike
11-17-2006, 01:00 PM
pa
Cobra Make, Engine: jbl in garage
Berm
I have the same problem being restricted to stock location. AFR 205 are like 1/8 higher which for me is a problem.
An alternative to consider is contact Ed Curtis at www.flowtechinduction.com. He is considered one of the best cam builder and head guys around. Ed does a thing with a special CNC program and gets the AFR 185 heads [ stock location] very very close to 205's flow numbers. While at it, ask him to build you a special custom cam for $395. Again his reputation is way up there.
Jack
PS flow numbers are great but velocity is king
11-17-2006, 03:10 PM
NV
Contact the manufacturer of the cam you have picked and ask him how much head you need. Ditto for Ed Curtis being very, very good. I have bought two sets of heads and one custom cam from him. Good guy and certainly knows his stuff.
11-17-2006, 03:34 PM
NY
Cobra Make, Engine: 1966 Griffith 400
best heads for 408...
good set of C# yates with stainless valves, not titanium. great flow for that displacement and price is much better now that SC1's are legal in nascar.
best of luck,
rrd
