| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
12-07-2006, 02:59 PM
oh
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Aluminum intake torque spec's
Looking for the torque spec's for one using ARP bolts with an aluminum intake manifold (air Gap) with SVO aluminum ford heads.
I also assume the tighting sequence to be the same a cast iron?
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
12-07-2006, 03:14 PM
Banned
CA
I started at 16ftlbs and then re-tightened to 20ftlbs after warm-up and cool down. Sequence is starting in the center and working across and outward to the corners.
-Dean
12-07-2006, 10:20 PM
CO
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
What do the specs say for your manifold RE: torque and pattern? Bolts do not matter whether they are ARP or Radio Shack Specials.
What matters is the torque and the pattern. Some manifolds require a different tightening sequence depending on MFG.
Once tightened warm the engine to operating temp checking for leaks, shut down.. then while engine is warm retighten to specs. Some say 3-5lbs more torque, others say to specs ... your choice.
I haven't warped an alum head or a manifold following this procedure and hve done it to MFG specs. But I'm not a mechanic either.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
12-07-2006, 11:02 PM
Oh, THAT kind of torque. For a minute there I thought you meant to imply that small blocks actually have torque.
12-07-2006, 11:07 PM
CO
Ernie,
You do remember the appropriate response to that.... if not
BITE ME and all SB owners
12-08-2006, 04:10 AM
oh
Never thought of looking at the manifold guys for the spec's. I'll check this out. Thanks
BTW...what is this BB vs SB stuff??? I thought this stuff only happened in boating...sailor boater vs power boater, guess I was wrong ; - )
12-08-2006, 09:27 AM
TX
tamanaco,
Stick around, you ain't seen nothing yet! For grins do a search on SB - BB
and you'll see what I mean. Heh heh - it is an on going saga.
Flip
12-08-2006, 06:49 PM
Ca
Ernie: Go back to sleep............Or better yet go drive around the island in circles
Rick
