01-12-2007, 08:30 AM
Ill
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
Junk Motor
Have any of you guys ever heard of a fuel injection leaning out off idle and trashing a motor to where 6 of 8 cylinders were 30% of the 2 decent cylinders on a compression test? By the way, the engine has less than 10 miles on it.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
01-12-2007, 10:51 AM
If you're talking about compression pressure, are you sure the rings are seated?
h dog
01-12-2007, 11:14 AM
Ill
Motor was built by an engine builder and dynoed before delivery. He is blaming the feul injection guy and the fuel injection guy is blaming the engine builder. Both have been paid and everything is supposedly warrantied, but guess who is stuck in the middle.
01-12-2007, 12:59 PM
Member of the north
Cobra Make, Engine: A Cobra
Get em all in a room...together.
It won't take long to sort out.
01-12-2007, 01:51 PM
IL
Cobra Make, Engine: SPF, KC 427
I'm don't know, but if the cars doesn't get gas then I would think it stops running and doesn't affect the motor. I say make them both pay half of the expense to fix it.
poolw
To my Cobra: - - when I'm with you - Oboy!
01-12-2007, 05:12 PM
Well, it is possible that it was run on the dyno under a too lean condition and burned holes in some of the pistons although I would think they could tell that right away with a dyno hooked up. Only way to tell what happened is to remove a head and have a look at the pistons. You can't point a finger until you know exactly what went wrong.
h dog
01-13-2007, 06:19 AM
Ill
Dyno runs usually have exhuast connected to a/f sensor. I have just never heard of a lean fuel mixture causing such a great amount of damage in less than 10 miles most of which was less than 40 mph. I would think it had to be mechanical like the timing jumped way in advance and caused detonation or something.
01-15-2007, 06:21 AM
Ill
Hey excaliber, you have already made this stupid comment. Are you not spamming yourself now? The hypocrisy of some people never ceases to amaze me and they are usually the worst offenders. Give it a rest dude.
01-15-2007, 08:11 AM
Oops, I MISSED one of your THREE THREADS on this subject. I should find it and post a SPAM warning there as well.
Like you, just trying to cover all the spam bases.
It is not good form to ask the same question over and over in various forums, you don't seem to get it.
01-26-2007, 09:26 AM
Ill
Update
Heads were removed. Pistons/cylinders show no signs of being burnt or excessivley worn. Engine is going on a stand next Monday and pistons will be pulled to check the rings. That leaves valves out of time with the pistons. Since it was dynoed at 650hp you gotta think the cam somehow slipped way out of time. It never did idle very well, but we attributed that to the injection needing fine tuning.
I am getting this 3rd hand so I have questions also.
01-27-2007, 12:25 PM
Il.
Engine woes
Jeff sorry to hear about the engine problems.
Hope you get them sortedout soon.
Ernie leave the guy alone, have you been sittin out
in the hawain sun too long?
Hey it's not winter in Hawaii shouldn't you be out beatin' on that Ex of yours?
The older I get, the faster I was........
So now I'm so fast apparently I appear to be standing still.
01-27-2007, 04:07 PM
Ill
Thanks Arcy, poor Bud has really be struggling with this. I think we will have him back on the road before spring and for sure before Byron. He should be a real contender.
Don't worry about the coconut, he reminds me of a drunk in the corner that is always mouthing off that nobody listens to. It makes him happy so you just leave him alone with it.
01-27-2007, 05:46 PM
Junk Motor: Small Block Talk, 13 replies, 530 views
Junk Motor: Backdraft Racing, 10 replies, 572 views
Junk Motor: Fuel Injection, 24 replies, 749 views
It would appear the Junk Motor "Fuel Injection" thread is the winner. Jeffko, Snake Oil, you might want to search out the other TWO threads and see what you've missed!
...freakin' spam...
01-27-2007, 06:02 PM
NC
...freakin' spam...
You need something creative to channel this anger into....lol.
James
Charlotte, NC
01-27-2007, 06:09 PM
Yeah, how about we channel it to the moderator. DONE!
Jeffko, you should have the common decency to alert the members you ARE running thread threads on the same subject and POST the necessary links in EACH on of them to cross reference. It's called 'NETiquette' (also known as courtesy).
01-27-2007, 06:24 PM
heavy hauler
Cobra Make, Engine: Shell Valley stroked 342
you're sure not showing any
I Planted...Watered....But God gave the increase....
01-27-2007, 06:37 PM
TTT
To the top, with all THREE threads!!
Be sure to post your slams in all three trctrdrvr
01-27-2007, 06:48 PM
heavy hauler
I have better use of my time, if someone is looking for info I don't care how many times they post, and If you feel slammed in was a repeat of you're own post so maybe you need to let you're brain catch up with you're a$$
01-27-2007, 06:50 PM
Stop it, guys....
There are only a few participating in the split conversation...
..pick one and stick to it, OK
thanks
ron
ClubCobra Moderator
