01-20-2007, 05:26 PM
Cobra Make, Engine: Hi-Tech
standard or HV oil pump?
I sure hope the stock roller block holds together, I'm shooting for 450hp at the flywheel.
Does anyone know if the oil valley girdle works?
What about the oil pump, I read somewhere a HV oil pump puts lots of strain on the distributor gear. Would a standard one work better?
01-20-2007, 06:03 PM
If you are building a full race motor with extra large clearances on the crank, go with a high volume pump to make up for the extra clearance. If not, a stock volume pump is more than adequate.
01-20-2007, 08:11 PM
Oil Pump
It's a 347, all forged internals, AFR 185 heads. Mostly street use, occasional road racing. So the standard pump will be best?
01-20-2007, 08:40 PM
Mi
Cobra Make, Engine: FFR Cobra 5.0 EFI 5 speed Trans
I've used Hv pumps in all my SB motors . I have never had a problem with them. I always use a HP distributor drive rod.All of my motors were Built for hi perforance use and still be driven on the street.Just my 2 cents worth.Roger
Roger S
01-20-2007, 09:21 PM
Stock pump.
Will help keep the distributor gear pin from shearing off.
01-20-2007, 09:32 PM
What are the bearing clearances? This is information that will dictate whether a HV pump will be necessary or advantageous.
01-20-2007, 09:50 PM
AZ.
First off A stock pump will work but without the buffer of a HV pump. If you add remote filters and coolers the HV will surely not hurt you. If this shears the distrib drive pin get a new and better one.
I think too heavy weight oil and oil not allowed to run at proper temp is by far a more common issue. Use the HV pump as a buffer for remote filters and coolers not used on STOCK pump designs and applications.
There will be some who say stock is better and some HV is better but an inexpensive upgrade with minimal possible downside. It is your Toy so do what seems right for you.
01-23-2007, 05:03 PM
Canadian Gashole
QC
Here is an interesting side point. My friend, who is an engine builder, always uses torque plates when boring and honing 302 blocks for 347 strokers. By the way, he prefers to use good quality standard oil pumps in street/strip engines.
Wayne
01-23-2007, 05:21 PM
Wayne
I agree with your engine builder. You'd be hard pressed to find a reputible engine builder that would recommend a HV pump for a street/strip car. It's just asking for trouble with ZERO benefits.
01-23-2007, 07:44 PM
AL
oil pumps
I have a 89 5.0 in my Cobra with a HV Melling oil pump. 65 psi cold and 50 hot. Water temp 195 and oil temp is 160 ( 7 qt oil pan ) 180 when I am a quart low. I orginal installed a HP / HV oil pump, pressure was 95 cold and 80 - 85 hot, 105 at 5700 rpm. I blew the remote oil filter o ring. Two and half quarts of oil up my windshield and thru my hair. I changed the oil pump! I have 17,000 miles on the motor / HV oil pump and no problems.
Dwight
01-23-2007, 08:30 PM
AB
Cobra Make, Engine: Butler Racing/427 side oiler
distributor
Does anyone else have problems with dist gears ..I go through them like their oil
Ive heard all the "normal" solutions just curious as to others ..its a MSD distributor
01-23-2007, 08:45 PM
Dwight
At what RPM are those pressures? If it's 6000 RPM, you're okay. If it's at idle, that's WAY too much.
I went through two bronze gears on with my MSD in a short period of time. Changed to a cast gear when I rebuilt the engine. No worries about the gear wearing out and putting all the bronze shavings in your engine.
Scott
01-23-2007, 09:06 PM
AB
went through the first one after the rebuild...(should have changed it out)
Then a bronze after about 250 miles. Changed to a iron or cast not positive...
and its not too bad after 250 more
thoughts?
01-24-2007, 04:08 AM
Cobra Make, Engine: BDR 302 AFR 165
M68 Hv
I run the above HV mellings pump no problems. Steel gear as per crane's recommendation no problem. MSD distributor hd pump shaft. I don't know why people take recommendations of what gear to run on there distibutor when you should call your cam manufacturer and find out. Good luck.
later
dennis
01-24-2007, 08:23 AM
VA
Here's a thought
How about a HV pump but with a stock bypass spring. This way you don't bump the pressure and put a load on the gear, but if you need it, you have the extra volume.
________
________
01-24-2007, 10:03 AM
Mine is the recommended cast gear for the cam shaft from the manufacturer, and after 5,000 miles there is no wear on the cam gear or the dist gear. I don't run the HV pump. Even when I had the mechanical roller cam before the rebuild I could have swithed out the bronze MSD dist gear for the steel one from Ford Racing.
Scott
01-24-2007, 11:31 AM
The problem tends to be the gear pin when used with a HV pump. There is a fix for it but unless an engine is designed to use a HV pump, it's best to just go with a standard pump. That's especially true when using a stock capicity oil pan.
01-30-2007, 04:18 AM
ny
Cobra Make, Engine: RUCC 390 FE TOPLOADER
High volume oil pumps create more problems than they prevent. I build a lot of engines for muscle cars and hot rods. A fresh engine with proper clearences DOES NOT need a high volume pump! I have seen cam gears and distributor gears wear out and broken drive shafts! I never use them!
JIM ZAG
01-30-2007, 02:24 PM
Ill
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
The amount of road racing you will do will lead to all the other decisions. If you road race with any duration and frequency then you must have a thermostatically controlled oil cooler. This leads to a high volume pump which in fact does put more strain on the distributor gear. The distributor gear is driven by the camshaft gear which is considerably harder and notoriously sharp. The bad thing is that, in my case MSD, use cast gears as a standard. You must have a steel gear with most all aftermarket cams. I bought a ford racing steel gear and had a machine shop install it. Some things you can not do yourself without big $$ in machining tools. If you look at the link below I further helped the problem by providing more oil to the cam gear/dist gear contact. The picture is at about 40 psi which is all my drill motor would produce. By the way, my idle psi is about 35-40 and cruising is about 65-70 and cold is about 85. Simply drill a .040 hole in the right bank oil galley plug. I also recommend the oil pump in the second link along with a billet drive shaft. I have 4500 demanding miles on my engine without any problems at all.
There is nothing harder on an engine, car too for that matter, than road racing. Drag racing does not even come close. Almost all street and drag race driven cars do just fine on a standard oil pump.
I may not be an expert, but I did a ton of research before I bought the first part for my engine. It is still just my two cents.
http://www.clubcobra.com/photopost/s...0&ppuser=20014
http://www.precisionoilpumps.com/ima..._Race_Pump.jpg
Tis better to burn out than to fade away. So "Lite 'Em Up!"
