Old 05-25-2007, 07:33 PM
onefastmustang's Avatar
Default Thermostat housing torque...?
Does anyone know the proper torque specs for a 351W thermostat housing?? I can't find it anywhere..
Old 05-25-2007, 09:14 PM
Cobra Make, Engine: SPF, 418 Stroker
I'm not a bolting expert, but here are some suggestions for you. 1. Tighten the bolts hand tight, sufficient that it doesn't leak. If you're going into aluminum, take care not to overtighten and strip the threads. 2. Check with the intake manufacturer and see what they recommend. 3: My 351W t-stat housing stays on quite nicely with about 15 ft-lbs (aluminum intake).
Old 05-25-2007, 11:01 PM
Thanks. I tried that and it's not leaking. I had to replace my old housing as it warped..
