Old 05-31-2007, 08:59 PM
onefastmustang's Avatar
Default Engine overheating
Yeah.. I am such a pest I know..
So my 351 is overheating.. Just all of a sudden it jumps up to 220 and then up to 280 before I shut it off. I went out and touched the upper hose and it was lukewarm at best. The bottom was rather hot.. Does this mean the thermostat is sticking on me??
Old 05-31-2007, 09:19 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Originally Posted by onefastmustang
... Does this mean the thermostat is sticking on me??
Take it out and see if that is your problem!
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 05-31-2007, 09:41 PM
Ralph
I just did that and its not overheating any more.. I guess that is the problem. Strange. It opens fine in a pot of water..
Old 05-31-2007, 09:49 PM
There a possibility that you have an air pocket in block's cooling passage. Do a search, I know I've read threads about your problem some time back.
Ralph
Burma Shave
Old 05-31-2007, 09:53 PM
I'm also wondering if my expansion tank is interfereing with the thermostat.. I have this one below.. The thermostat goes inside the housing that accompanies it and then the assembly bolts on. It seems to me that this design may have issues with a balanced sleeve thermostat since it has an extra peice of metal between the housing and the intake manifold. Anyone ever used this tank with a balanced sleeve tstat?
Old 05-31-2007, 09:55 PM
When I first got my car it was always running in the 200 -220 range with a 180* T-stat. Put in a 160* and now runs between 160 and 180, even on fairly hot days.
Ralph
Burma Shave
