Old 06-29-2007, 03:51 PM
Default Rocker arm clearance
I am in the process of having a 351W built and wondered about valve cover choices. I wanted the use the Ford black wrinkle "cobra" lettered covers. These are stock height, any concern with roller rocker arm clearance?
I would love to hear from someone using them with rollers on any SB Ford.
Old 06-29-2007, 06:38 PM
Barnsnake's Avatar
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
I'm running that combo with no problems on Edelbrock heads. I should note that I'm not running a lot of cam lift (.496).
Jim
A Gnat! Quick, get a sledgehammer!
Old 06-30-2007, 07:58 AM
Roscoe's Avatar
I'm using AFR 185's with Harland Sharp roller rockers on my 351W. I used the tall 'Cobra' covers from Tony Branda.
Roscoe
Roscoe
Old 07-06-2007, 07:47 PM
Smile Rocker clearance
I have 1.7 roller rockers and a b303 cam(.512 lift) with black cobra covers with no clearance issues. I did remove a baffle from inside the cover though.
Old 07-07-2007, 06:05 AM
WildBill3's Avatar
we are running more lift that that but with a jesel shaft system and it clears ..wild
