| 29 |
07-16-2007, 09:44 AM
AL
HP vs TQ question
I have done a search but have not found the threads I was looking for. So I'll ask the question.
Can someone explain the relationship of HP / TQ? A commend was made about HP being more important at the drag strip. Another commend about Nascar engines have 800 HP and 400 foot lb. of TQ. I understand that if you want to go 200 mph you need an engine that will turn high rpms to get you to 200 mph but you need TQ to push the car to that speed. What is the ratio?
Dwight
07-16-2007, 10:05 AM
For racing purposes, especially oval racing, it's all about HP! Torque defines the ability of an engine to do a certain job, HP defines how fast it can do it. 300 FT-LBS of torque is far more valuable at 5,500 RPM than it is at 2,500 RPM.
HP = (torque X RPM) / 5252
07-16-2007, 10:25 AM
I posed a similar question years ago to an ole mechanic and asked him to give me a answer that a dumb a$$ like myself would understand, he thought for a second and then said;
You know when your on the entrance ramp to an interstate doing about 20 mph???? then you accelerate to say 70 mph and blend in???? Torque gets you to 70 mph, horse power keeps you there once you hit your speed and level off...............
makes since to me..............
DAVID GAGNARD
07-16-2007, 10:28 AM
IL
Cobra Make, Engine: 427 Cobra re-creation based on Kirkham aluminum body and chassis, Original 1965 Ford 427 Side Oiler and Ford Toploader transmission
An favorite quote on the subject from a friend on another forum.
"Horsepower is how fast you hit the wall, torque is how far you take the wall with you."
Along those same lines:
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car."
07-16-2007, 11:25 AM
Torque has no time function, HP does! It's all about HP. Transmissions and differentials can always increase torque but they don't increase HP. 800 Ft-LBS is not very useful at 100 RPM (waterwheel effect). 400 FT-LBS at 6,000 RPM is far more valuable.
07-16-2007, 11:32 AM
Tell that to a guy with a diesel hauling 40,000 lbs in the trailer.
Both are very useful when used in the appropriate application. If the car is primarily street driven I prefer a wide torque band over a peaky horsepower curve. The track is a different animal and you want the HP up high in the RPM range where you will be running the engine.
07-16-2007, 02:02 PM
SI
You cannot measure HP without knowing what Torque you have first.
Lets say for some crazy reason you decide you need 800 HP @ 7000rpm.
To obtain that you simply just keep developing the combination until you have
600 ft/lb of torque @ 7000rpm, you only get torque readings from the dyno, the HP is simply a calculation from that reading in conjunction with RPM with allowances for Temp-Humidity etc.
BHP = [(RPM x Torque) divided by 5250]
Torque= [(BHP x 5250) divided by RPM]
Jac Mac
Banned
I recall someone once telling me that "Torque gets you up to a certain speed and Horsepower keeps you there." Works in NASCAR.
07-16-2007, 03:20 PM
Stolen Avitar
GA
In this same vein someone once told me this;
“You feel torque from the seat of your pants much more than you feel horsepower.”
The human butt can no more distinguish torque from HP than it can blue light from red light. In simplest terms we are dealing with power or energy, a force that moves you. These forces are expressed in mathematical terms thusly;
1 HP = 33,000 foot-pounds per minute (there’s that over time thing that Bob mentioned)
Or it could be P/hp=[T/(ft lb)][w/(r/min)]
5252
By the way, that 5252 is why nearly all dyno charts show the HP and torque curves crossing at that RPM.
Or it could be 746 watts
Or maybe 2,545 BTUs (British thermal units)
One BTU being equal to 1,055 joules, or 252 gram-calories or 0.252 food calories.
This means that 1 HP is also equal to 2684975 joules, or 63504 gram-calories, or 641.34 food calories
Presumably, a horse producing 1 horsepower would burn about 641 Calories in one hour if it were 100% efficient.
The point is that its energy, a force, what moves you, not some nebulous calculation as others have postulated.
Torque is the force applied to a lever, multiplied by its distance from the lever's fulcrum in our case a theoretical lever and a rotating fulcrum, or more simply:
T = r x F (whadaya know another calculated theoretical number)
Which is linier force multiplied by a radius. Of course this formula always assumes a perpendicular force axis to the fulcrum, something that just doesn’t happen in a reciprocating engine for more than a millisecond at a time.
From the Ole mechanic “You know when your on the entrance ramp to an interstate doing about 20 mph???? then you accelerate to say 70 mph and blend in???? Torque gets you to 70 mph, horse power keeps you there once you hit your speed and level off...............”
To put this into perspective the next time you want to accelerate really fast try shifting at your engine’s torque peak rather than the HP peak. It doesn’t take a rocket scientist figure out using which shift point will accelerate the car faster. This is because we’re talking about energy expended over time not a static applied force. To say that another way; I could put 84 pounds (that’s a Buell motorcycle’s peak output) of torque on the bike’s crank shaft with a ratchet handle, but I don’t think it’s going to accelerate too quickly and I doubt that the rider’d feel it to much in the seat of his pants either.
I find the whole argument over HP vs. Torque to be silly in the extreme because they are really one and the same, just expressed differently to show how the power is produced in any given engine for any given application. For instance a tow vehicle was mentioned; do we want high RPM power for our tow rig? I think not, we want it down low so that it’s managable and produces minimum wear on moving parts. How about the drag car? We want as much power as possible and since an internal combustion engine is in effect an air pump then we want as much air as possible to pass through the engine. All things being equal, the faster the engine is turned, the more air goes through it, the more power is made over any given period of time.
In summary, to disassociate HP and bow to torque is like saying that you really like chocolate cake but that chocolate is over rated. It just doesn’t make sense.
Steve
07-16-2007, 03:37 PM
So I guess both tractors and bulldozers will be good at getting up to speed on entrance ramps. The Formula 1 guys are making a mistake winding their engines up to 19,000 RPM.
I can produce 300 FT-LBS of torque on my bicycle, why is it I can only get up to 25 MPH?
07-16-2007, 03:38 PM
AL
dyno chart
OK Steve
Why is my Tq more than my hp? Would you look at my dyno chart and tell me what is happening and why?
Dwight
I hope you can see the picture of the chart
07-16-2007, 03:47 PM
HP = TORQUE x RPM / 5252.
Notice where the lines cross.
07-16-2007, 04:03 PM
AL
rpm
To go 200 mph your engine has to turn enough rpms. You have a transmission, rear end gears and tire size to help.
I know it takes a certain amount of torque to get you to speed and keep you there.
Dwight
Second Strike Gearing Calculator
Specify Transmission and Rear Axle Ratio
Tremec TKO-600 5-speed (0.64 5th) 3.55 Rear Axle Ratio
Specify Rear Tire Size
255 Rear Tire Width 50 Rear Tire Aspect Ratio 16 Rear Rim Diameter
Speed (MPH) in Gears at RPM
Gear 1st 2nd 3rd 4th 5th
Trans Ratio 2.87 1.89 1.28 1.00 0.64
Overall Ratio 10.19 6.71 4.54 3.55 2.27
Split 1.52 1.48 1.28 1.56
Rev/Mile 8,142 5,362 3,631 2,837 1,816
1500 11 17 25 32 50
2000 15 22 33 42 66
2500 18 28 41 53 83
3000 22 34 50 63 99
3500 26 39 58 74 116
4000 29 45 66 85 132
4500 33 50 74 95 149
5000 37 56 83 106 165
5500 41 62 91 116 182
6000 44 67 99 127 198
6500 48 73 107 137 215
7000 52 78 116 148 231
07-16-2007, 04:27 PM
SI
Do you really want my thoughts on this????
Jac Mac
07-16-2007, 04:44 PM
NJ
Tq/hp
I just had this discussion with Tom Kirkham. At both VIR and Watkins Glen, the fastest 427 Cobra I have seen runs in the 2.08 - 2.09. We all know what the car weighs. The Gt 350's also run around the same. When I had 4027, my best time was in the high 2.12's at The Glen. My former Winston Cup car has run The Glen and VIR at 1.58 - 1.59. That's a whole lot faster and a whole lot heavier. It was 780hp/500tq.
I think most buidt Cobra's as street monsters with way too much torque. The last 427 we built as a standard bore/standard stroke dynoed at 551hp and 565 tq. The motor is a killer on the street but I would have preferred to kill the torque a bit, like to under 500 and bring up the hp. That would have taken a bigger cam making it less streetable. You can't have everything.
The cup motors are set up great. It would be neat to see what a well set up Cobra would do with real Cup Power and not a version of.
But.........going that fast in a car as unsafe as a Cobra as opposed to a cup car is a bit nuts also.
Cheaper,safer,faster to have a Cup Car
07-16-2007, 07:49 PM
AL
I found it
OK It took a while but I found this link to a site that was posted on the FFR Form. With our Cobras there are other factor to consider, like aerodynamic, HP, torque and lots of other things that make us go fast. I think Mr. L.E. Mayfield has very interesting information for us.
Here is the link to the site, http://www.mayfco.com/cobra.htm
Dwight
Automotive Analyses
Return to Mayfield Motor Sports Homepage
Return to Automotive Analyses Homepage
FFCobra Forum Question: How fast is my Cobra with this much horsepower?
This also works for all vehicles, shhhh!
INTRO
Once upon a time, in a land far away, I was a huge fan of the original Cobra and it's final originator, Shelby. I went to the plant is Southern California, but at the time was a starving student or just out of school at Cal Poly, SLO. I could not swing the 6 grand or so, so I quietly walked away. Then I bought a used Tiger. Jeeze, I am off track and have just started this. Well, anyway, I spent an entire career with the Boeing Company doing odd jobs. Some of them involved aerodynamics and such.
Now I know how you all feel about your cars, Cobras, whether or not original or a reproduction. I know that many of you are true performance fans and have hopped up your cars to the n th degree. But, after all that hopping up, you find that there is little in the way of knowing just how fast it is or can be. Roads with the public on them just aren't the way to go and the drag strip just isn't quite enough either. What I have done for my Tiger, I am gonna try and do for you. I am going to develop a set of tools that you can use to figure it all out: "Just how fast will my Cobra go?"
Now you will have to go to his site to finish reading the article. With the charts it was to large to post here. Dwight
07-16-2007, 07:59 PM
Originally Posted by Dwight
OK Steve
Dwight
The simple answer is your engine doesn't have the torque where you need it to make the HP you want. This can be due to many things (exhaust, cam, heads, intake, etc.) That's why we test on the dyno and make changes to see if we can make more power (or move the torque we have).
If you could take the peak torque you have of about 350 lb/ft and move it up the rpm scale (eaiser said than done) from 4500 rpm to say 7500 rpm you'd have 500 HP (350 X 7500 / 5252 = 500 HP).
This is why some of us build strokers to make more torque at a lower engine speed to make the power we want.
07-16-2007, 08:44 PM
AL
What would it take to move it to 6000 rpm?
Here is what I have
weight 2315 no gas 17 gal fuel cell 185 lb driver
8.8 '89 Mustang rear end with 3:55 gears and BFG G-Force tires ( 25.25" tall)
4 link with adjustable coil overs
54.5% rear weight and 46.3% front
TKO 600 with 2.87 1.89 1.28 1.0 .64 gears
10 1/2" McLeod clutch, 50 oz billel steel flywheel
96 5.0 truck block
Eagle forged 3.47" crank, SIR 540CB forged rods, SRP forged pistons #144995
354 cid 10.67 CR
Romac aluminum 50 oz damper
all rotating assembly balanced by local shop
Comp cam XE274HR-12
Brand: COMP Cams
Product Line: COMP Cams Xtreme Energy Camshafts
Part Type: Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,200-6,200
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 232
Duration at 050 inch Lift: 224 int./232 exh.
Advertised Intake Duration: 274
Advertised Exhaust Duration: 282
Advertised Duration: 274 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.555 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.565 in.
Valve Lift with Factory Rocker Arm Ratio: 0.555 int./0.565 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Grind Number: FW XE274HR-12
1.7 roller rockers
Pro Com aluminum heads: 190cc runners - 60cc combustion camber - raised exh port .25"
int. 2.02" & 1.6" exh valves -- heads will flow approx. 270cfm intake and 200 cfm exh @600 lift
36 lb injectors and a Granatelli 90 mm mass air meter
Mallery multi spark ignition box and a 89 Mustang computer A9L with a
Custom SCT chip to make it all work together. Car dyno'ed with chip.
Melling HV oil pump 65 cold idle & 30 hot psi
Holley SysMax II upper and lower intake
73 mm BBK throttle body
stock 89 Mustang distributor
8.5 mm MSD wires
7 qt Cannon oil pan
3/8" fuel line, stock 89 Mustang fuel rail, holley fuel pump 255 lph #HLL-512-105, adjustable pressure regulator set at 38.5 lb.
March aluminum pulleys, under drive on crank and water pump only
1 5/8" equal length header 40" long dumping into 3 1/2" side pipes
I would like to move the tq & HP up to the 2500-6200 rpm range. I also would like the tq & hp to be close to the same. 375 / 375 rear wheel would be nice. What do you guys think I need to change?
If there is any more info you need just ask. Thanks for the help.
Dwight
07-16-2007, 09:19 PM
Dwight
More torque.... LOL...
Sorry.
400 lb/ft would be about 450 hp & 450 lb/ft would be close to 515.
The real question is how do you get that torque from the 350 you have now?
There's no magic wand.
07-16-2007, 09:33 PM
Something to keep in mind during this discussion..... Torque is the actual force pushing down on the piston, HP is just a calculated number. Improve your torque, and you improve your power. The key is making the torque you need WHERE you need it.
Sal Mennella
