Old 08-18-2007, 09:41 AM
Cobra Make, Engine: X Everett Morrison, X SPF 140, X SPF1823, currently SPF2778
Default Flywheel position make a difference?
I'm re-installing my flywheel and I cannot find my mark to put it back in the same place. Am I in trouble? If so, how do I fix it so balance is not messed up? Will engine balance be affected if I install it wrong?
Its a steel 157 tooth Ford Motor Sport flywheel on a 392 FMS crate engine. It has a 4" weight on the front side of the wheel. I read the Ford Motor sport web site and it lists several different types of flywheels, but I could not find any notes, warnings or cautions about installation and balance.
Please give me your advice!
Thanks,
Tom
Old 08-18-2007, 10:14 AM
lovehamr's Avatar
Stolen Avitar
It should only line up in one position man.
Steve
Old 08-18-2007, 10:38 AM
imagine2frolic's Avatar
Cobra Make, Engine: n/a
Send a message via Yahoo to imagine2frolic
Or possibly you could get a vibration like lovehamr's AVATAR!!!!!!
20mph is not fast, unless you are doing it in a 3/2, 1000sq. ft. house on 10 ft. waves!
Old 08-18-2007, 12:24 PM
SuperHart's Avatar
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Don't worry. Just place the flywheel on the hub and rotate until all the bolt holes line up perfectly. The bolt holes are slightly misaligned to avoid attaching the flywheel in the wrong position. It's difficult to see the misalignment by just looking at it. While I'm on a roll here, be SURE to coat the bolts with a thread sealer before screwing them in. Oil leaks can occur through unsealed threads.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Old 08-18-2007, 12:39 PM
Superhart:
Thank you very much for the good news! It's me proof. Even I couldn't screw it up.
Tom
