Old 12-02-2007, 09:39 AM
MrMagoo's Avatar
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
Default AFR 185 Exhaust Port Size
My new crate motor has AFR 185 heads. I placed my old header gasket (a Fel-Pro 1415) on the exhaust ports, and I notice that they are larger than the gasket. Whereas the old stock ports were rectangular, these are rounded at the top, and larger.
AFR's website says use the Fel-Pro 1415, which seems odd since the ports are bigger.
If I can see you, I'm too close
Old 12-03-2007, 10:42 AM
MrMagoo's Avatar
I think I hit the mother lode here...
http://www.spdexhaust.com/downloadsD.html
This seems to be the only answer: weld `em up. The AFR 185 uses the "D-Roof" style.
These guys are also a possibility: http://www.cprparts.com/products/hea...ders_main.html
Old 12-03-2007, 10:54 AM
RACER X #99's Avatar
Deleted info
SAAC member and supporter
Club Cranky charter member
Old 12-03-2007, 11:02 AM
MrMagoo's Avatar
These aren't quite so much oval as "D" roofed, but I'll check those out.
Old 12-03-2007, 12:29 PM
MrMagoo's Avatar
More gold. This sums up my problem quite nicely.
http://www.stahlheaders.com/ports.htm
I talked to AFR today, and the gentleman manning the help desk told me that the basic problem was the 2" header bolt spacing, which doesn't allow enough room to run the bigger exhaust pipes. Makes sense.
One solution which Stahl offers is an adapter plate. It has recessed bolts for the two inch holes, and then gives you larger ports with the 3" spacing that you can weld up your big pipes to. Somewhat fugly, but your other choices are to say forget it and use the old restrictive headers, or have your cylinder heads drilled for 3" spacing.
UPDATE: not as bad as I feared.
A template as described at the stahl headers link. You tap with a ball peen hammer against the edge of the ports and it makes a nice clean cut.
I placed the template on one of the headers. These are "backdraft type" slip fit headers that are in the process of being de-slip fitted. They are about 1 3/4" diameter at the flange.
You can see that there is some blockage along the sides of the port, but top and bottom the header flange hole is pretty close to the cylinder head exhaust port size.
I'm not going to get my boxers twisted up over this.
