Old 05-20-2008, 02:29 PM
smallblockhead's Avatar
Cobra Make, Engine: ex-owner ERA FIA 2062
Default Need Oil Slinger for SBF
Does anyone know where I can get my hands on an oil slinger for a 289 Ford engine? It’s a cupped washer that fits between the crank timing gear and harmonic damper and keeps most of the oil in the timing cover off the back of the crankshaft seal. It was probably a $2 part back then, but I can’t seem to find one without buying a whole engine!
Any leads would be appreciated. I already tried DSC Motorsports…his response, “all out, call back next month, I may have one then”
Thanks,
Gary
Old 05-20-2008, 03:09 PM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Should be the same as a 302/ 5.0 engine. Have you tried the Ford dealer for one using those engines. The 289 part probably isn't listed or is called "obsolete", but one for a 302 should be easy to locate.
WDZ
Old 05-20-2008, 08:22 PM
PANAVIA's Avatar
I will look in my 289 buckets.
Old 05-22-2008, 08:45 AM
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
The oil slinger has been discontinued by Ford, and is not available new. Also, it will not fit under a late model 5.0 timing chain cover, without some mods to the cover. Due to improvements in seal technology, Ford decided the slinger wasn't necessary.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
Old 05-22-2008, 09:30 AM
DAVID GAGNARD's Avatar
Thanks,
Gary
Locally, your best bet is a junk yard......
How many do you need?????? I probably have at least a half dozen, you can have one, just tell me were to send it to....
Do you want one that's all nice and grimy like it came off the motor or one that's been cleaned up and bead blasted to look new?????????????
Let me know........I can get it out to you by tomorrow morning, after that I'm heading to the camp for the holiday weekend.......
David
DAVID GAGNARD
Old 05-25-2008, 04:33 PM
David,
I tried to send you an e-mail, but it bounced. I can do a grimy one if you have one. PM me for address.
Gary
Old 05-27-2008, 03:21 PM
Gary;
PM sent to you, been gone for the holiday weekend..........
David
DAVID GAGNARD
Old 05-29-2008, 01:28 PM
Thanks for everyone's inputs/suggestions, and a special thanks to David who sent me one for Free! Who couldn't like Club Cobra! Good people!
Gary
Old 05-31-2008, 05:22 PM
Gary;
I know what it's like to have to search junk yards for parts and get nickel and dimed to death, so since buildng my shop about ten years ago, I throw away almost nothing.........
The other day I was looking for something and came across a five gallon bucket 3/4 full of head bolts for a 302 and 351s..when ever I tear down a motor, I save all the little things like the slinger and put them in five gallon buckets or army surplus wood ammo boxes.....never know when you'll need a part or extra bolts.....
I'm always using the old head bolts for some project.....
I finally threw away two original Ford cast iron 4V intakes for a 351-W....saved them for soo long and nobody wanted them, one day while cleaning up, I decided I was tired of moving those heavy things out of the way......you know, a few months later someone was looking for one.....
The way I figure it, if I have a spare, chances are I'll never need it,meaning my junk will not brake down, but throw it away and within 3 days, you'll need it......happens every time........
Glad I could help you out............
David
DAVID GAGNARD
Old 07-04-2008, 09:20 PM
Default Oil Slinger
You can purchase oil slingers here:
http://www.dscmotorsport.com/asp/pro...t=84&GroupID=3
Good Luck!
Old 10-28-2009, 11:58 AM
hey do you haveany left? icould use one&do not care what it looks like...thanx
Old 10-28-2009, 12:07 PM
I'll have to check, but I think I'm down to my last "spare".......you wouldn't believe the folks that emailed me for one and I gave everyone that asked one!!!!!!!!!!!!!!!!!!!!!
David
DAVID GAGNARD
Old 12-23-2009, 03:35 PM
RET_COP's Avatar
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
So, do you really need one? I thought I read that if you are using a double roller timing set, the slinger just gets in the way and you need to bend it for clearance?
Lou
Old 12-24-2009, 02:35 PM
Lou
Fit perfectly on my 351-W and 331 race motor, both have double roller timing chains.............
David
DAVID GAGNARD
