Old 07-19-2008, 08:25 AM
iwantacobra427's Avatar
Cobra Make, Engine: SOLD: ERA FIA #2114 with 331
Default MSD Distributor
I purchased a MSD distributor for a 302 while forgetting the cam is for a 351. I guess I have to use a distributor for a 351 since the firing order is different? I set the valve lash as if it's a 351 engine.
Old 07-19-2008, 09:19 AM
TButtrick's Avatar
351W Dizzy is dimensionally different and won't work. 302HO is same firing order as 351W. Regardless, all you'd need to do is swap the wires.
1-3-7-2-6-5-4-8
Old 07-19-2008, 09:31 AM
Default I have a 1978 302 so the firing order is different than
the 5.0 L and 351 W. So I can just arrange the ignition wires according to the distributor and 351 W firing order?
Old 07-19-2008, 10:21 AM
jwd's Avatar
jwd jwd is offline
That's all you need to do.
Old 07-20-2008, 09:09 AM
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
You will also need to insure the gear on the distributor is compatible with the cam. Steel roller cams use a steel gear, and cast iron flat tappet cams use a cast distributor gear. There should be some documentation that came with the distributor as to what cam gear was installed. If you mismatch these components, the distributor or the cam gear will get worn to almost nothing, requiring a complete engine tear down and cleaning to get all the metal particles from the gears out of the engine.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
