Old 03-04-2009, 08:50 AM
onefastmustang's Avatar
Default Switching to Roller Rockers
I am switching to roller rockers this week but from the looks of them they may not fit under my valve covers.. Any suggestions on dealing with that? Are there risers that can be bought so I can keep my VC's or suggested VCs?
Old 03-04-2009, 08:55 AM
Ron61's Avatar
Post
What I did was go to Felpro and they make a laminated extra thick valve cover gasket that gave me plenty of room for my roller rockers and no leaks. I guess it would depend on just how tall your covers are to start with. I had the normal finned Cobra type. Also check that the baffles inside the valve covers aren't going to be a problem. And I do believe that you can get a 1/2 inch space from Cobra Restorers now to add under the valve covers, but you have to watch to see that it doesn't cause a hood clearance problem.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 03-04-2009, 10:19 AM
Snakebit's Avatar
What type of valve covers do you have? I have a pair of Buddy Bar cast aluminum on mine with CompCams Pro Magnum roller rockers. I had to remove the baffle inside the valve cover and purchased aluminum tubes with baffles for the air filters. I use Moroso steel core valve cover gaskets with out any clearance problems.
Snakebit
Old 03-04-2009, 10:30 AM
marcalan's Avatar
Cobra Make, Engine: era 289 FIA #2112
I got some aluminum spacers to allow the roller rockers to fit under the stock style valve covers.
live for the moment or it may pass you by
Old 03-04-2009, 10:40 AM
1985 CCX's Avatar
Spacers!
They are available from various sources, they look nice as well.
Old 03-04-2009, 09:47 PM
I have 3 different sets of valve covers.. I will have to see if any fit with no ding.. If not I may go the spacer way.. I'm cheap.. what can I say..
Old 03-06-2009, 12:45 AM
PANAVIA's Avatar
or you could get those oloff FE-to-windsor valve cover spacers and be able to use FE valve covers where i swear you could lay a redbull can ontop of your valve train (sideways of course --) and have it not touch the valve covers.
Old 03-07-2009, 03:57 PM
I did have a pair of Ford Performance covers that fit perfectly at 3.75 inches deep. I want to use my finned COBRA ones at some point though but they are only 3 inches deep. I guess spacers are in my future.
