03-19-2009, 05:15 AM
mi
Cobra Make, Engine: jcf slabside,302 ford
5.0 -t5 questions
Anyone know how far down from the oil pan lip to the oil level is in inches on a standard 5.0 or a 289?
Has anyone used any Amsoil atf in there T-5? and how did it work?
03-19-2009, 10:59 AM
mi
could use some help.
03-19-2009, 11:51 PM
not sure on question # 1, it would depend on if the engine is running or not.
I would take a bare pan and pour in 3 qts and measure.
for question #2, couldnt hurt, seems $$$$
BTW: mobil1 Dextron III is my favorite.
03-20-2009, 05:46 AM
3 qts or 4? Weren't they 5 qts including with the filter?
03-20-2009, 06:23 AM
OK
Terry,
On my Canton oil pan I poured in six quarts water (mine is a 7 quart pan) and the oil level came up to within about 3 1/2 inches of the rim. If you have the 289 with the dipstick in the side of the pan I would expect the oil level would fall just below the dipstick.
As far as Amsoil...it seems to be pretty popular at the drag strip witht the Mustang guys. If there was something bad about Amsoil we would all know pretty quickly because a lot of people around here are on top of things and get the word out if something is less than it is supposed to be.
Clois Harlan
"Let's roll"
"Be part of Something Good
03-20-2009, 07:04 AM
va
Cobra Make, Engine: BDR #250
not sure about AMSOIL but I have used GM Sycro-mesh for years. This last time i switched to Royal purple sycro mesh
03-22-2009, 04:54 PM
mi
Thanks for the help. Does the ford f-1 filter hold 1 qt of fluid?
It looks like the oil level is different on each pan ford used.
03-22-2009, 08:29 PM
Yes, it is rated at 1 Qt capacity.
03-22-2009, 11:25 PM
dont forget all the oil in the galleys,valleys, and lifters.
when we pump an engine full of oil prior to first start, we usually loose about a quart.
03-23-2009, 03:38 AM
mi
So thats where the 3 qt comes from, 1 in the filter 1 in the engine itself, leaving 3 in the pan not 4 as you would think?
04-01-2009, 02:46 AM
Thats the idea. -- 3 to 3.5 in the pan at rest.
04-01-2009, 09:01 AM
mi
Thanks Steve, I still am a little confused about all the conflecting info about the right fluid for the wc t-5
