Old 08-21-2009, 06:58 AM
zrayr's Avatar
Cobra Make, Engine: Fords
Originally Posted by Caprimaniac View Post
Mechanic isn't stupid at all. An option to consider.
Is the mech pump OK when you rev the engine to say 8000 rpm?
You'll still need the pressure regulator?
Hmm... Not sure if there's room for one, though.
RS
yes, the better carter mechanical pumps are ok to 8000 & beyond. You will need a regulator if running Webbers, no regulator otherwise.
Z.
'65 K code Mustang
'66 Galaxie 500
Old 08-21-2009, 09:12 AM
N2VENOM's Avatar
Cobra Make, Engine: Kirkham KMP500 LeMans- Roush 451 Shelby block; KMP Flip-top with cammer: KMP 289 Bronze under construction.
I have a Aeroquip on my Kirkham and until I installed rubber isolators it was way too loud. The 1/2" isolators cut the sound in half without anymore vibration.
Old 08-25-2009, 09:46 AM
Caprimaniac's Avatar
Thanks, Zrayr.
Only thing that comes to my mind: I might have put the camshaft sprocket on wtihout the assymetric pump- lifter thing on.... then a bit more work if I decide to put in a mechanical...
Might have to strip the thing down anyways?
RuneS
Old 08-25-2009, 10:19 AM
I mounted a Walbro GSS340 pump in a baffled area with check doors in the tank. Feeds an Aeromotive by-pass regulator with #8 (1/2") supply and return lines. Quiet as the proverbial church mouse.
Rodger
Old 08-25-2009, 11:06 AM
priobe's Avatar
N2Venom,
do you have pics of you pump with the isolators
