Old 05-23-2009, 07:57 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
Default Cam Degreeing
I am building a 71 302 with some mild performance parts. I like to degree the cam on engines that are not just stock. I use the center line method that this cam company likes and it's just one degree off. Not bad. My roller timing set just has four degree adjustments so I figure it's not worth messing with.
I'm all set up so I figure I might as well check it further the old way, by checking the opening and closing degrees based on the cam card. I find the intake opening is fine but the intake closing is five degrees to long. The exhaust opening and closing are right on. So I end up with an intake duration that is 265 and exhaust is 260. I then set up everything on another cylinder and sure enough the same thing. It looks like the cam was ground wrong.
The specs are:
At .006 int open 24 BTDC close 56 ABDC
Actual Was open 24 BTDC close 61 ABDC (5 deg off)
I call the cam company and they say pay for shipping and send it to them. They will check it out, if it's bad they will send me another one. So, one week there, they have it a week, one week back, no motor work for three weeks.
The questions for cam experts, what is the down side to running this cam with five degrees more intake duration on the closing side than it is supposed to have, making it with a longer duration than the exhaust?
