Old 07-05-2009, 11:00 AM
Default 426 cleveland stroker
1st cleveland and love it. any word on stroked 426 clevelands? need some feedback by Ford guys and not sales people. Thanks
Old 07-05-2009, 12:04 PM
1985 CCX's Avatar
Sounds cool? Reliable?
Old 07-09-2009, 11:45 PM
I assume you're referring to a 9.500 block?
The more motor you give a Cleveland head the better it likes it.
Old 07-10-2009, 05:20 AM
I don't think you can get there with a 9.200" block, and if you could, I wouldn't recommend it. Clevelands are not known for thick cylinder wall thicknesses. That much of a stroke would put a lot of side loading on the walls.
A lot of builders don't even like to go to 408 with Cleveland blocks.
Old 07-12-2009, 04:30 PM
Cobra Make, Engine: Factory Five replica and unknown replica
Bounty 1,
I run Clevelands in my Pantera's and am just finishing up a 408 stroker. That's about as large as you can make a cleveland because of the deck height and wall thickness. If you're running the early 4V closed chamber heads with that combo you should be able to get 500 + horsepower and torque out of a 10.5 compression engine with right cam and a little head work.
If you need more cubes you're going to have to go to a Windsor or Clevor block like the Dart. You can take the 9.5 deck height Dart all the way to 454 cubes.
Old 07-12-2009, 07:25 PM
Jac Mac's Avatar
Short of finding one of the 'Rare' Siamese blocks designated for Nascar in the mid/late 70's that were cast in the USA then shipped to Aussie for machineing etc its a 'Risky Business' Im even more conservative than these guys when it comes to the production blocks, wont bore them past 4.030", wont build them with less than a 6" rod even at 3.5" stroke. Why, I learnt the hard way---- the more you stroke em the more they broke em' & I hate doing things twice for no good reason.
Jac Mac
Old 07-12-2009, 08:57 PM
LoBelly's Avatar
I think maybe its a reference to the new Boss351 block
http://www.autoblog.com/2009/06/13/f...-engine-block/
available in 9.2 & 9.5 deck height
from the article...
"Max stroke is up to 4.25" depending on crankshaft manufacturer with max bore size topping out at 4.125" with coolant cross drilling. A non cross-drilled block with increased bore capacity will be available by 3rd quarter."
guessing this would get you a 4.00 x 4.125 in a 9.2in block (?)
LoBelly
Old 07-12-2009, 09:09 PM
767Jockey's Avatar
Go over to the Cleveland forum, there's a guy named Tod Buttermore who has developed a new Cleveland block with an much improved main priority oiling system. It's supposed to accomodate significantly larger bore and stroke parameters than a standard Cleveland block, and it's available in both iron and aluminum.
Old 07-13-2009, 11:09 PM
Tod's block isn't ready yet but will have better oiling and the ability to go with a bigger bore but still has the 9.2 Cleveland deck height. The Boss 351 block is similar to the Dart World Style block and a bunch of Dart copies now coming in from China that are basically Windsor blocks with the Cleveland 2.75 main bearings and 4 bolt main bearing caps.
Old 07-19-2009, 03:01 AM
PANAVIA's Avatar
Shade Tree--
your comment "Dart copies now coming in from China " -- what have you seen >? are they showing up as off brands or are they trying to sell them as Dart/SVO/etc >?
--Steve
Old 07-19-2009, 04:25 PM
Originally Posted by PANAVIA View Post
Shade Tree--
--Steve
It looks just like a Dart Iron Eagle...Dick has stopped anyone from selling them, last I heard.
Old 07-20-2009, 12:16 AM
PANAVIA's Avatar
There was a book out by George Reid that explained stroked small blocks, and there was some Cleavland info therein. I think there was a 426 possible with a 9.2" deck if memory serves.
http://www.amazon.com/Build-Big-Inch.../dp/1884089836
Old 07-20-2009, 11:13 AM
You could do it.
But you'd wake up screaming in a puddle of cold sweat for months afterward.
Old 07-20-2009, 12:22 PM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Here is the only company making this kit and I hear that their quality is questionable.
http://www.speedomotive.com/ps-127-1...roker-kit.aspx
After speaking with many Cleveland builders no one recommends going over 4" stroke. Keith Craft only recommends 393's.
Tod Buttermore will also be producing a 9.5" deck block at some point which should get you 460ci, pair that up with some nice CHI heads and you should easily make 700hp. A 408 will get you over 600hp with these heads.
Cobrarich
Old 07-20-2009, 11:37 PM
Me, I'm with Keith.
Old 07-21-2009, 03:32 PM
What is the problem? Are the cylinder walls cracking at a 4.0" or 4.1" stroke?
The piston compression height is shorter in a 347 than a 426 Cleveland would be.
Old 07-21-2009, 04:04 PM
Jac Mac's Avatar
Apart from the std clevo cyl wall thickness problem its stroke & rod ratio( and the resulting angle), not pin height that are the real issue.
On the 3.4" stroke / 5.4 rod this ratio is 1.588/1 with the 302 8.200" block.
Clevo with 4" stroke/6.125" rod is 1.531/1 in 9.2" block with 1.075 pin height.
Jac Mac
Old 07-21-2009, 04:17 PM
I see a lot of 4.0" stroke with 6.0" rods in 408 Clevelands (1.5 ratio).
A 426C with a 4.1" stroke and 6.0" rods is 1.46 ratio.
Does piston speed also play a role in the destruction of Cleveland cylinder walls?
Old 07-21-2009, 04:49 PM
jdean's Avatar
Yeah around 1.5 ratio is about the same as a stock BBC 454 which has 1.53....the bowtie bunch dont complain much....and they push a lot of power with them.
6th generation Texan....
Old 07-21-2009, 05:08 PM
Jac Mac's Avatar
Its kinda hard to isolate piston speed, it comes with the territory in longer strokes & if the owner insists on pushing the RPM it does become a major factor. Depends on what the application is really, Put it in a class where the high RPM is not continous & the stroker will probably last, try it in a boat or circuit car ( Road course or Nascar long track types ) where high revs are for longer periods and the short rod combo will self distruct.
The best example that we probably have here is the SBF combos of: 4.125 bore X 3.25" stroke versus the 4.00" bore by 3.40" stroke. Both are the same capacity @ around 346/347 ci, but the short stroke/big bore motor can rev higher, yet really gives nothing away down low either.
Clevos are pretty popular down under with the Aussie Falcon crowd & an easy swap to a 6" rod ( The 302c had a 6" rod/3.00" stroke ) plus an Aussie 1.425" pin height piston makes a nicer motor out of the 351c & virtually eliminates the bore cracking problem.
One other problem the std 351c has, the std rod/piston combo pulls the piston skirt well below the cyl bore @ BDC, the 6" rod cures that, but it returns again if you lengthen the stroke, on the Jet Boats we worked with that ran continous @ around 5500 plus the piston skirt would get a very defined 'mark' on the skirt where the piston 'rocked' @ BDC largely due to the lack of bore support.
Jac Mac
