Old 08-24-2009, 06:31 PM
zrayr's Avatar
Cobra Make, Engine: Fords
Originally Posted by m5extc View Post
Just a suggestion,
I had a simular problem. I readjusted the throttle linkage. I suspected all of the same things, then thought that the linkage on mine is hard, not a cable so maybe it's an issue. The motor mounts flex just enough on hard braking to push the throttle closed a little more, shoking the engine. My problem isn't completely cured but is 100% better now after adjusting the rod differently.
Andrei
THAT WAS IT, but the flex wasn't closing the throttles, it was this:
I just have determined the problem lies in the accelerator pumps circuit. I had them adjusted per Holley's instructions, with a little pre-load, so the action is immediate. The problem was, when the brakes are on hard, the throttle linkage is tweaked enough to give a squirt of gas into the closed carb venturies. I tightened up on the acc. pump screw slightly, which gives a little clearance before the acc. pump is activated. This one about drove me off the deep end.
thanks for all the help,
Z. Ray
'65 K code Mustang
'66 Galaxie 500
Old 08-24-2009, 06:33 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Can you get someone to lend you a different carb.
You might want to consider the process of elimination. Swap out parts until the problem goes away.
Just the thought.
Old 08-24-2009, 07:27 PM
Good work! I must look at mine tomorrow. Please post on your "fix". Might be the same problem a lot of people have.
Old 09-06-2009, 12:35 AM
Thanks for sharing the great list and have done a great article with complete and interesting information. I found my state in the list and enjoy your article too. Thanks again for nice information.
