Go Back   Club Cobra > General Discussion > Suggestions
Old 11-07-2015, 09:50 AM
1985 CCX's Avatar
Default Racedeck flooring.
Met the Racedeck team at SEMA 15.
Great design and very personable as approachable.
A must for every garage.
The carpeted tiles are cool. Warmer for Northeast.
Will be an addition to my garage for sure.
Old 11-07-2015, 10:07 AM
streetrod1927's Avatar
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
Jeff: I did my garage using "Garage Flooring LLC" products. I found it more pliable and better priced. They were easy to work with as well and sent several samples prior to my purchase.
Ralph
Old 11-07-2015, 01:55 PM
Al G's Avatar
Cobra Make, Engine: Sold - Shelby Cobra CSX6045, 468 ci all aluminum Shelby engine
I love my Racedeck floor. Buy directly from them for the best price.
Old 11-07-2015, 05:24 PM
Been covered before. I had some issues that made me pull it back out. My garage faces south and if I left the doors up the expansion from sun would move and buckle it. I did leave 3/4" gap around edges as instructed. Had problem when I pulled bus motorhome into garage if I stopped or turn the wheel ever so much, would buckle and make mess, weight I guess. Granted my garage is 2800 sq. ft. which might be some of problem. Might not be as big problem with 2 car garage. The company sent someone out to look at problem's and his answer was to put some screws thru the floor into concrete, that did not work. I pulled it up and put black and white 12"x 12" tile down with half the thin set thickness because of weight, no more problems. Went to mexico and picked up porcelain tiles for .59 cents each. Have about 1500 sq. ft. left of what I pulled up if anyone wants some cheap and can come to central ca. to pick it up. Black and White Racedeck with some trim pieces.
Old 11-08-2015, 11:01 AM
1985 CCX's Avatar
Did you ever call them on this?
In the Northeast seems different.
Especially as they have vented tiles.
KMS has there whole shop in this stuff. Looked great to me.
I have u basement and limited in garage. I do like the tiles with carpet concept.
Old 11-08-2015, 12:39 PM
It looks great, but not ideal as a working surface. Especially if you had a oil spill. It will run through all the gaps and be a horror to clean up. I like the idea of stick down tiles better. Even a painted floor.
JD
Old 11-08-2015, 12:59 PM
Rjw289's Avatar
Cobra Make, Engine: Contemporary Classic 289 FIA
Very happy with mine. Purchased from Costco and customer service was excellent after purchasing a couple items direct from manufacturer. Some of my trim measurements were wrong and they provided some items free.
Old 11-08-2015, 01:46 PM
Bernica's Avatar
Senior CC Premier Member
I have used these guys on many of my commercial and industrial projects and the stuff is good. Will plan on using it on my new garage (when I get it built!).
I have seen big trucks and forklifts twist and turn on it and about everything else and it seems bulletproof! They can also cove it up the walls so you can literally steam clean your entire place if need be.
Industrial Commercial Flooring, Epoxy Floor Systems, Resin & Urethane Floors | Stonhard
Old 11-10-2015, 02:07 PM
Dangerous Doug's Avatar
Razerwire: Sent you a PM.
DD
Dangerous Doug
"You're kidding, right?"
Old 11-10-2015, 02:30 PM
LMH's Avatar
LMH LMH is offline
Glad I re-read your headline! At first glance, I thought it said "Redneck Flooring"!
Alba gu brąth
