Go Back   Club Cobra > General Discussion > Suggestions
Like Tree1Likes
  • 1 Post By EM-0785
Old 09-30-2020, 02:15 PM
Cobra Make, Engine: Butler with 351 Winsor
Default Radiator
Hi All,
I have a Butler Frame with a 351 Winsor that is built to put out 504 horses (allegedly). I need some help on a cooling system, specifically a radiator. I have very specific specs for size, 26 wide by 19 high (or I get into clearance issues). What have others done? I am preferring a dual "puller" fan setup but I do see a lot of pushers. Experience trumps all my research. Thanks for your guidance!
Old 10-01-2020, 11:14 AM
1985 CCX's Avatar
Fluidyne made for the Shelby 427
Have had 3 and they are well performing units
Old 10-01-2020, 12:56 PM
EM-0785's Avatar
Senior CC Premier Member
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
Hi Bob,
As Jeff referenced, you may want to check out the Fluidyne.
I was similarly concerned about size/spacing and their FHP35-Shelby Cobra Radiator dropped in absolutely perfectly, with my Everett Morrison's mounting anyway.
I believe the radiator dimensions are: 23.7" L x 18" H x 3.5" D (to be verified).
Obviously you'd want to verify your depth for the 3.5".
The radiator does seem to work well in all regards in my application.
Best of luck! Brent
1985 CCX likes this.
Tags
cooling system, radiator
