Old 10-09-2009, 01:02 PM
Cobra Make, Engine: SPF 02345, Roush/Yates 358 Sprint Cup motor
Default Brembo brakes
has anyone upgraded their SPF brakes to Brembos? If so do please tell....
Old 10-09-2009, 06:07 PM
I think that a large group of SPF owners have upgraded to the larger Wilwood brakes. If you track your car, the upgrade is worth the expense according to several of my friends who have done it.
I believe you can buy an upgrade kit from Dennis Olthoff (or any Superformance dealer for that matter) and install it yourself if you are handy.
Old 10-10-2009, 01:35 AM
PANAVIA's Avatar
There are 6 piston upgrades for the front from Wilwood, but I am un-aware of a rear caliper update.
Old 10-10-2009, 07:11 AM
RonNichols's Avatar
Cobra Make, Engine: SPF398/460ci/ 144hp of backfiring fury
I did a Wilwood big brake upgrade on the fronts last October. I upgraded from the standard SL4 caliper to an SL6. I have 15" wheels and all I needed was a 3mm spacer which I ordered from Skulte Performance. They customed machined it to my specs and all is GREAT! No fade on the track now.
The rear calipers on the early cars require a simple bracket to be fab'ed to go from a cast iron 97mm spaced Ford floating caliper to a narrow mount 5.25" Wilwood dyna pro. The offset needs to be .835" . I did mine this last summer with a .810" x 11.75" GT directional vane rotor with a .720 depth aluminum hat. USe a 45degree adaptor from the brake line to the caliper for wider wheels
You will not need a spacer for this.
Rumor has it though, there is something in the pipeline on a Brembo big brake kit. It is only a rumor at this point, and has only come up in drunken conversation, from somebody who knows somebody....etc. You can do a Wilwood upgrade all the way around for about $3000. Double it if you want a Brembo name.
If I continue to track this car, and carbon/carbon ceramic brakes come down in price, I wouldn't mind putting together a brake system for my car from Brembo.
R
Old 10-25-2009, 06:24 PM
RonNichols's Avatar
Here's a Wilwood upgrade from Superformance themselves. It appears that it comes with a new spindle also. Seems like a good price for what you get.
http://cgi.ebay.com/ebaymotors/Wilwo...item3ef985d4d4
R
Old 10-29-2009, 08:33 PM
thanks for the heads up Ron, i will give them a call.
R
