February 2026
Old 12-19-2009, 09:13 PM
JA COBRA's Avatar
Cobra Make, Engine: superformance 460/ stroked to 521
Default Billboard tire pressure
Just Purchased billboard tires and am wondering about pressure? how much pressure should be in the tires to properly balance them,and afterwards how much pressure in them to drive with.The tires i drive with have 18 pounds in them now.I have seen alot of guys in this forum with billboards,hope someone can give me some advice.
Old 12-20-2009, 02:17 AM
xlr8or's Avatar
I ran mine at about 26-28.
Old 12-20-2009, 03:00 AM
Silverback51's Avatar
I run 22 - 18.
John Hall
Old 12-20-2009, 07:48 AM
Banned
I typically run 26 front and 24 rear for street driving. Dropping it 2-4 psi from those levels will really improve the grip.
-Dean
Old 12-20-2009, 08:17 AM
JA COBRA's Avatar
-Dean
How about when you had them put on and balanced did they have to be filled to what it says on sidewall? and then you lowered them to 24 &26.
Old 12-20-2009, 08:23 AM
Banned
Don't recall, but I had them road-force balanced.
Old 12-20-2009, 08:26 AM
JA COBRA's Avatar
No problem i know of a shop nearby that does the road force balancing.
Thanks for the response.
Old 12-20-2009, 08:52 AM
Kramer's Avatar
Cobra Make, Engine: ERA 739
I agree with the 26-28 psi measurement. I don't run mine much lower unless I am on the track but even then it is closer to 20-22. I am sure everyone is different but I don't know why you would ever run these tires under 20.
PS...Since you are up north as well, I thought I would tell you to check your pressure often as you store the Cobra. At least every two months(maybe more often), you will need to add some air to these tires.
Kramer
Old 12-20-2009, 09:07 AM
I used to run higher pressures, but when it was on the dyno it was spinning the tires at 22 psi. We lowered them to 18 in the rear so it would hook up, and I just left them there for the street. I have never had an issue with them at 18 psi, so that is what I run now.
John Hall
Old 12-20-2009, 11:28 AM
dcdoug's Avatar
I find that 2-4 psi in either direction makes a pretty big difference for my car. It handles best on the street at 28psi front, 26 psi rear. The tires start to hunt a lot when it gets down below 24 psi.
www.partskeeper.com
Old 12-20-2009, 12:18 PM
1985 CCX's Avatar
A agree with Dean......... 26/24
Old 12-20-2009, 06:54 PM
I've had them for 4k-5k miles. For street driving I reduced the hunting/darting some by airing up the front to 30 psi, rears at 28 psi. I could probably go a little higher, but the car feels good at these pressures.
David
