February 2026
Old 02-09-2010, 12:44 PM
Cobra Make, Engine: Superformance, 427R, SPO2561
Default Softer pipes
Is anyone aware of aftermarket pipes that are quieter than the factory side pipes?
Old 02-09-2010, 12:46 PM
Banned
Mark, you'll probably snuff out that 427R if you go any quieter than an already quiet factory pipe. My $0.02. Try some 30db foam ear plugs, available in bulk at Home Depot. I never leave the garage without them. Then again, I'm running a custom 3" ID muffler and my car is certainly louder than most.
-Dean
Old 02-09-2010, 02:20 PM
Got the Bug's Avatar
Mark,
You might want to check in with the folks at Olthoff to see what they would recommend.
http://www.olthoffracing.com/
I know that Stephen at Full Throttle has done a lot off different side pipe configurations for SPF cars (I believe he primarily works with Classic Chambered).
http://www.fullthrottlereno.com/
http://www.classicchambered.com/classic/purchase.html
Like Dean said, you'll trade some performance for quieter pipes, but you may enjoy your car more.
Doug
Old 02-09-2010, 02:35 PM
RodKnock's Avatar
Hushpower was purchased by Flowmaster and is now a division of Flowmaster. They were recommended to me and I like them a lot. Allegedly, they're quieter and less restrictive. I have no proof.
http://www.hushpower.com/
Old 02-09-2010, 08:24 PM
Bartruff1's Avatar
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
absolutely not..
Old 02-10-2010, 02:41 PM
Default Go
Check these out ; Buttrick uses them says they work , FFR application , sure it could be fabed up to work on a Super .
http://www.breezeautomotive.com/deta...=545&cat_id=26
SDR
________
MARIJUANA HEMP
Old 02-11-2010, 02:35 PM
bobcowan's Avatar
There was a very long thread about this not very long ago. Had a lot of good data, and solid objective testing, along with some subjective opinions.
I recently removed my stock FFR pipes, and welded in some much longer classic chambered mufflers. I had one side old stock, and one new. I started it for a minute in the garage, and it certainly seemed to be quieter. But only only idled for about a minute in the garage, not a very good test. But I'll get the job done this week end (I hope) and then do some real testing.
Old 02-11-2010, 03:22 PM
Snakebit's Avatar
If you want softer pipes, stop taking Viagra! When I am ready to leave a car show every one stands around to hear it start with the loud pipes. You are not one of those who have have a cup holder and a stereo in their Cobra are you????
Snakebit
Old 02-11-2010, 03:23 PM
Banned
I was waiting for this...
Old 02-11-2010, 07:24 PM
My car has the auger type inserts, very tolerable at crusising speeds but still roar at wot, they actually increased the hp.
Old 02-13-2010, 09:36 PM
Rare Iron's Avatar
Well now, this just ain't true. Quieter & better flow IS possible. Stephen usually orders the 3" unpacked versions because his customers like them the best. BUT, 95% of the 'Packs I build are with packing (noise absorbing) & no complaints. 2.5" are good to upper 400 HP range & they are quieter than the 3" ones. 3" ones are full-boogie high HP class, & not too loud either.
-Eric
Old 02-13-2010, 09:42 PM
-Eric
Thanks for clarifying Eric! I'm planning on getting some new pipes built one these days. I'd like to go quieter...don't really car what others say and happy I won't be sacrificing performance.
Doug
Old 02-14-2010, 07:30 PM
bobcowan's Avatar
I just finished installing a set of Eric's mufflers. I really like the results. Havn't been for a test drive yet - too cold. But in the driveway they sound great.
You can see more pictures here: http://s13.photobucket.com/albums/a2...red%20Exhaust/
I have sound bites from the stock FFR mufflers, but I don't know how to post them.
Old 02-14-2010, 08:17 PM
Cobra Make, Engine: NAF 1965 427 bodied w/Clevland 351 bored 60 over toploader 4 speed White and grey stripes
I agree that some pipes are too loud at 67 years old i have almost blown out my hearing.My Cobra is loud and fast as is but Cal Cops dont have a sense of humour and its only a matter of time that I will need to quiet my car down. too open pipes over scavange the motor and you end up running lean this is a good way to burn valves and piston tops. Good luck keep it upright. Larry Spillman
Old 02-23-2010, 12:57 PM
Cobra Make, Engine: SPF 2137, Roush 427R-170
I am curious as to what brand/size auger inserts you used and what set up (pipes)you put them in and what kind of power did you pick up. I have a Superformance with 427R that I put new stepped headers 1 3/4 to 1 7/8 and new Howe 3 1/2 ID race mufflers with their race merge collectors. I am putting down 468 rwhp with a junk carb. Next step is to get rid of the 870 Holley Avenger that my dyno guy can't get to run right (will get Pro Systems). I really like the performance and the deep sound of the pipes but they are just insanely too loud (my wife thought I would never say that). I do not want to go to the expense of complete new pipes (just spent a ton on this new set up) so I am looking for some way to quite these down a little. Any thoughts, pics, as to what you did on yours would be greatly appreciated.
Jon
Old 02-25-2010, 11:23 PM
WardL's Avatar
Vettes have a baffle that opens up at 3000 rpm. You can put the baffles on a switch and open for loud and close for softer. I haven't seen them on a Cobra.
Tags
spo 2561 roush 427r
