| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
04-05-2010, 09:05 PM
ca
Cobra Make, Engine: SPF2914 Sunset / Titanium
One wire alternator? really not the same!!
Okay, I know all of the typical Q & A that goes on regarding this subject as I have been involved as well. My question is this. I want to retain the red light by tapping into the blue wire, but have read that this will not work with an ampmeter. I have yet to figure out why or what function is lost. Is this true, and if so, does anyone know what the issue is? Please advise.
Andrei
04-06-2010, 01:59 AM
CA
Large SI cased GM alternators actually have three terminals.
A> BAT+ for your Solenoid BAT+ Lug on the firewall.
B> Dual Terminal Side Connector ; look for the #1 connector this is stamped with a #1 on the case, this terminal is used to connect to the dash warning light,
--which is wired in series with a 12V+ IGN on only signal . in case of issue, the #1 terminal will *THEN* act as a ground wire, thereby illuminating the waring lamp.
give it a try.
04-06-2010, 08:56 AM
ca
Steve,
I have tried that and it works. My question is, that I have read that you should only do this with a volt meter and never an amp meter, and I have not yet been able to figure out why or if this is even correct.
Andrei
04-06-2010, 01:24 PM
Cobra Make, Engine: SPF#0760
SPFWiringDiagrams@Comcast.net
04-06-2010, 01:52 PM
CA
The thing is , you could use the 95A Gen 3 Motorcraft and be ford-o-riffic at the same time.
Andrei -- one should not be using an AMP gauge that is UNDER the rating of the ALT.
in the case of the SPF, the AMP rating is 50/+/- -- whereas the 10SI 1 wire is atleast 90A.
