Old 04-08-2010, 06:19 PM
Default SPF 402 header
Hi all. Anyone know if its the 402 header is the one to use on the ford Motorsport Z head.
Anyone know this info? The header I have now is the standard 351W header. Not a good match for the Z head. Anyone have pics?
Old 04-08-2010, 09:03 PM
bump anyone?
Old 04-10-2010, 03:14 AM
PANAVIA's Avatar
I thought this was done by timeline and not by size.
Are you referring to the M-6049-Z304A head >?
Old 04-10-2010, 04:00 AM
thanks for the reply
yes that is the head im talking about, will the 402 header work for those heads? are the header ports large enough?
Old 04-10-2010, 05:48 PM
bump bump bump
Old 04-10-2010, 07:00 PM
Cobra Make, Engine: SPF #2899 Dart 440 stroker 771 hp w/nitrous
101 I have a set of headers from hillbank to fit the large ports (slightly used) or check out firefly performance.com Ron is an spf guy
Old 04-13-2010, 10:19 AM
i sent you a message in regards to your slightly used pipes.
Old 04-13-2010, 10:21 AM
anyone else have any info on this issue? or has a set of headers for sale that fit the spf with the Z heads.
Old 04-13-2010, 09:11 PM
no one? there has got to be some one!
Old 04-13-2010, 09:29 PM
Maxum 101
I'm not sure about the 402 headers or specifically what they are. But the "Z" heads do need a header that is different from what SPF supplied a few years ago. The original SPF SBF headers were for a rectangular port that was not vertically centered around the bolt holes. I know that SPF has made changes over the last few years with a few improvements to the exhaust port to header mating.
The Firefly "Z" headers are not cheap but they are a great design.
http://www.fireflyperformance.com/ Ron builds SS sidepipes and headers.
Jim 1855
Old 04-13-2010, 10:07 PM
thudmaster's Avatar
Regularly Offensive
Cobra Make, Engine: spf
just a thought.......take a look at the pictures in this post it might help
Superformance Exhaust
Ed
Too close for missles, switching to guns.........
Old 04-13-2010, 11:32 PM
greg schroeder's Avatar
It would help if you proided the dimensions of your exhaust ports.
off idle drag pass, DA 750ft.
Old 04-14-2010, 04:04 AM
MAX - Check with Hillbank to verify but I'm almost positive they'll fit the Z heads(99%)
402 have the double bolt pattern and fits afr as well as dart heads. 419.376.2585 MT
Old 04-14-2010, 08:29 AM
in another post you said you had a set slightly used.... are you selling that set you talked about?
Old 04-14-2010, 08:33 AM
called ford but no luck with the guy i had on the phone, looking into other places to get that info
Old 04-14-2010, 08:35 AM
i called hillbank they have a 351w race header , here is a pic of it
there shows nothing on the parts website for a 402 header.
Old 04-14-2010, 08:39 AM
and this is one of the 402 header,
Old 04-14-2010, 08:41 AM
anyone looking to sell a set, ?
Old 04-15-2010, 09:01 AM
still looking for some help on this one.
Old 04-15-2010, 06:42 PM
Default SPF Large port headers
Got them! mtylinski@yahoo.com
