Old 06-20-2010, 12:18 PM
Kenm4187's Avatar
Cobra Make, Engine: SPF# 2560
Smile Converted from Original Spinners to 5-Lug Wheels
Just converted from original spinners (with 17" wheels) to new 5-lug wheels (18").
With the change I was able to get wider wheels and also drop over 13 pounds on each rear wheel and 9 pounds on each front wheel. What a big change for Auto-X.
Old 06-26-2010, 12:22 AM
Tonkin NZ's Avatar
Cobra Make, Engine: Indigo Superformance MkIII. Ford 460, TKO600
A shame. It is what makes these stand out from cheeaper imitations in my view.
For details on SPF2828 - click here
Old 06-26-2010, 01:36 AM
FatBoy's Avatar
I'm with Tonkin. When most other owners want to upgrade to pin-drives, you're going the other way.
Why didn't you just get some 17" pin-drive wheels?
You've given me an idea, I'm going to swap my nasty polished aluminium body for a GRP one.
Paul
Old 06-26-2010, 04:51 AM
Silverback51's Avatar
I also prefer the looks of the knock off wheels, but if you read his post, he did it to reduce the unsprung weight to improve the handling.
Considering the lower speeds of most autocross courses, I'm wondering if it really made a difference.
John Hall
Old 06-26-2010, 01:15 PM
Slick61's Avatar
Wow... quite a difference in unsprung weight. Let us know how much difference you feel.
I like the look, though obviously, it's not everyones cup of tea. Unless you're driving an original... they're ALL imitations. Everyone's priorties are different... some favor originality, some favor all-out performance. To each his own.
That said... you've got to be prepared for both praise and criticism when posting pics & seeking opinions on this site. The key is just to enjoy your car!
R. Smith
Santa Clarita, CA
Old 06-26-2010, 01:54 PM
Quik289's Avatar
Cobra Make, Engine: ERA 2137, KC Racing 306
Sure like the way the new wheels and tires fit the wheel openings. The car LOOKS tougher and faster.
Old 06-26-2010, 02:12 PM
Got the Bug's Avatar
Is the rear wing really that effective at autocross speeds? Did you drill though the trunk to mount it?
Doug
Old 06-26-2010, 02:32 PM
Ya know, Auto Cross is VERY competitive. If your going to run to win you gotta do what you gotta do. If you don't, one of those "cheap imitations" is gonna kick your butt.
Old 06-26-2010, 05:42 PM
Kenm4187's Avatar
I had 17 pin drive and the wheels and adapters are heavy. The wheels go on and off a lot and I have had issues with the spinners, got one seized and had to cut it off.Big difference in the car with the lighter wheels. Got 315's in the front and 335's in the rear now.
The spoilers do help but should go all the way across the back of the car. When I ordered the car I ordered an extra trunk lid so I could put the spoiler on and not damage the car. I did not go all the way across because I did not want to damage the paint or have to add holes in the areas I could not replace.
The best part is I can put the adapters back on and run the 15" pin drive wheels (stock) when I want to drive it on the street.
Old 06-26-2010, 07:31 PM
The weight difference between the Avon CR6ZZ tires and the Goodyear BB's was 12.5 pounds on the front, and 10 pounds on the rear, per tire.
Going to a race tire will save you a similar amount of weight per corner.
John Hall
Old 06-26-2010, 08:08 PM
Kenm4187's Avatar
I went from Kumho V710's to the Hossier A6's. Both are comp tires.
The new 315's were 2 pounds heavier than the old 275's tires (front) but I still saved 9 pounds per wheel after the wheel and tire change. The wheels went from 9.5 to 10.5 inches wide.
The new 335"s were 1 pound lighter than the old 315's tires (rear), but I saved over 13 pounds on the wheel and tire change. The wheels went from 11 to 11.5 inches wide.
Ken
Old 06-27-2010, 06:08 AM
Woodz428's Avatar
I didn't even notice the spoiler when I originally looked at the pics. So when I went back to look I also noticed the rollbar. Is that an SPF special order or was that one that you had fabbed after you got the car? I didn't see any leftover holes in the bodywork( but I didn't look closely), so it would appear that you ordered it with the car.
WDZ
Old 06-27-2010, 08:28 PM
Kenm4187's Avatar
That is a factory rollbar that I ordered the car with. One problem is the bar is not high enough and I have to get it modified.
Ken
Old 07-28-2010, 07:52 PM
fordracer's Avatar
Cobra Make, Engine: I had lots of little Cobras until Oscar the house thief stole all of them
Sorry kind of late posting here. I really like the wheels. I bet that thing looks really mean in person. As for the haters, 18" bolt on wheels and wing or not, at least you are spending your Saturday racing instead of waxing.
I Put a Jihad on You....
Old 07-28-2010, 08:29 PM
Kenm4187's Avatar
Amen, that's why I got the car (to use it).
http://www.clubcobra.com/photopost/d...bra_marina.jpg
Old 07-30-2010, 01:07 AM
PANAVIA's Avatar
Not my cup a tea, - but if it makes him happy.
Old 07-30-2010, 03:22 AM
Mando's Avatar
I can see how it would be viewed by the purists, and I would love to have knock ons on my car but those wheels look fan-bloody-tastic. I love them. Because they're not Halibrands I don't even notice the spinners are missing. Great stuff.
Regards.
Mando
Old 07-31-2010, 07:00 PM
What seat did you put in and did you have to fab anything? Getting rear ended with the factory seat is probably not a good outcome. Luv the rims but I would stay with 15 inch.
Old 07-31-2010, 08:05 PM
Kenm4187's Avatar
I put a Corbeau seat in, fixed in place. Just added a 1" square tube on the front to raise it. Grade 8 bolts down through the frame. I'm a big guy so I need all the room I can get. The seat is turned a little more to the left so the peddles line up better.
I like the 15" wheels for cruising but I can't get the tires I want for that size wheel. The good news is I can put the factory wheels back on for street driving.
Old 08-01-2010, 05:11 AM
What offset/backspacing are the new rims?
