Old 08-15-2010, 09:45 PM
cobrasnake's Avatar
Cobra Make, Engine: SPF, Roush 427R
Default Heater Control Cable replacement
My heater control cable has separated between the brass sleeve just behind the dash and the black plastic wrapped jacket. Metal duct tape holds the two sides together on a temporary basis since I can not recrimp the two sections.
Does anyone know the replacement part as that has to be easier than trying to repair the cable?
Thanks - Tom
Old 08-18-2010, 03:30 PM
Okiesnake's Avatar
Cobra Make, Engine: Unique 427SC, 351W
I have no idea how your SPF cable is set up, but when I set up my Cobra, I used a manual choke assembly that you can buy at most any auto parts store. The pull knob looks authentic.
Good luck.
Old 09-29-2010, 05:19 PM
cobrasnake's Avatar
Okie - thanks, been busy and just saw your response. I was hoping someone might know the length or part number. I will do some research on a choke cable. I would like to keep my existing knob. So far, the tape is holding up nicely.
Old 10-02-2010, 03:13 AM
PANAVIA's Avatar
I have one that would be a perfect replacement - they are all "Cut to Fit" i can show you how , no big deal to get it nailed. --
