Old 10-01-2010, 02:24 PM
Cobra Make, Engine: SPF 2234 Diamond Edition, Roush 427R
Default Removing plastic from sidepipes
Hi!
Maybe this help someone.
Had my cars to get a few weeks away cause of registry. Yesterday i was getting my car back. What a hazzle - On each side of the pipes 2 big black plastic burnes from a plastic trouser on the section with the 4 pipes.
and at the rear section a burn from a plastic bag. Have tried a lot of things: petroleum, thinner, terpentine, alcohol, polish...
But had no chance to get it of. Tried it with hot pipes...with plastic knives, wood, ice...everything i tried did not work.
Now i have tried it with a soldering lamp...was taking the hottest part of the flame directly on the creamic coat and what a surprise with a wet kitchen cloth you can rub most of it of - polishing - soldering lamp again - polsihing.... The flame is a lot hotter as the pipes when hot from driving. But the ceramic coat resists. Of course its no fun and a lot of work but after 3 hours the pipes looks like new. (and my hands are burned)
Old 10-08-2010, 02:10 AM
boblyon1's Avatar
Cobra Make, Engine: SPF #633, 351w stroker, Tremec 3550
I had a similar problem and ended up using acetone and 0000 steel wool on cold pipes. (uncoated) Took some time but got the junk off.
"All that is necessary for the triumph of evil is that good men do nothing" - Edmund Burke
Old 10-08-2010, 03:05 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Get them good and HOT and spray cold water on the plastic!!
The water will "Flash Solidify" the plastic so you may scrape it off with a wooden paint stir stick or something that won't melt or scratch the finish??
I have never done this but AirBorne Coatings told me this will work in the event I pick up a plastic bag on mine.......GOOD LUCK!!
Old 10-16-2010, 02:38 PM
Fattyd's Avatar
Cobra Make, Engine: SPF #1694, Royal Blue w/Vintage White Stripes, Roush 402R motor
I heard EZ-OFF oven cleaner works too. Buddy used it on his Harley pipes in similar dilemma. Not sure if it really works??
It Ain't The Life You Choose But The Life You Live
