Old 02-02-2011, 03:09 PM
Default Heel and toe shifting in an SPF.
Okay, I can heel and toe with the best of them in my previous cobra, but this one has the gas pedal right next to the brake pedal so that I can't turn my foot at an angle like I used to and rest my toe on the brake and my heel on the gas.
The only way I can heel and toe in this car is to use the left side of the ball of my foot on the brake and the right side on the gas. Real uncomfortable this way.
Is there any way to modify/adjust the gas pedal so that it is lower than the brake pedal? What do you guys do?
Old 02-02-2011, 04:13 PM
fordracing65's Avatar
call olthoff racing, get a brake and clutch pedal extension, then your gas pedal will be lower than your other pedals.
PRIDEnJOY
Old 02-02-2011, 04:14 PM
209 209 is offline
Cobra Make, Engine: Superformance 2765 Roush 427(POS) with cruise.
Hi Jim,
Apparently I'm a little dense here. Why or what situation would you need to heel and toe? I don't think I've needed to do that once. Oh, stopping uphill? 209
Old 02-02-2011, 04:22 PM
crASH's Avatar
http://en.wikipedia.org/wiki/Heel-and-toe
Old 02-02-2011, 04:38 PM
Cobra Make, Engine: Kirkham coyote
Well maybe if they had a decent handbrake you wouldnt need to heel and toe
Old 02-02-2011, 04:46 PM
Silverback51's Avatar
It's for down shifting.
And I do not have any problem with doing it in mine.
John Hall
Old 02-02-2011, 07:02 PM
Exactly, it's for down shifting while braking into a corner so you match revs and get into the right gear to exit the corner without shocking the drive train and possibly upsetting the cars balance at a critical time.
And it sounds cool too!
Old 02-02-2011, 07:03 PM
Thanks, that's just what I was looking for.
Old 02-03-2011, 07:48 AM
Originally Posted by 209 View Post
Hi Jim,
Because you really cannot drive them the way they are intended without utilizing heal toe.
Old 02-03-2011, 08:02 AM
Cobra Make, Engine: Titanium/Black BDR934, Ford
Same problem on my BDR, gas pedal is too high when depressing the brake pedal. I'm going to ask Reg at Custom Cars to adjust the gas pedal lower for me when I take it in for service next month. Nothing beats the feeling of a well executed heel and toe ( almost nothing ;-) )
Fred
Titanium/Black BackDraft Racing 934
351 Windsor
Old 02-03-2011, 08:11 PM
Cobra Make, Engine: Superformance 427R
I bought my car from a short guy and I'm 6'2", so I had to remove the pedal extensions. I also cut 2" off my gas pedal, which was shaped like a hockey stick and may have also been a special adaptation for short people. If you think you can use the pedal extensions, PM me with your address and I'll mail them to you.
Old 03-02-2011, 05:55 PM
the pedal is too low, has too much travel, and the master cylinder is garbage and the bias is a disaster.
I yanked all that that crap out, properly mounted a tilton dual master cylinder with bias bar and pedals... I'll try to send you pics and info if you want to email me.... ramey@rameylegal.com
unfortunately, i learned that the spf brakes, pedals, steering and front geometry must be completely redesigned unless you are just wanting to live with a show car only level of performance on 60's technology tires.
Old 03-02-2011, 07:40 PM
Seems like the SPF show cars did okay at the 2010 Run N Gun - taking top honors in several categories.
Old 03-03-2011, 12:10 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Ramey,
Just from the tone of your post...
Are you the guy with the silver Superformance with the extreme modifications listed to the chassis and suspension, Wheels, tires, and SO much more... and had it for sale at one time I believe? on eBay maybe? in 2008 & 2009 & in 2010?
Edit: Don't bother answering that question...you are the guy...I just revisited your ebay sales ads describing the car and the modifications you made to the other deficiencies on the factory cars...
SPFWiringDiagrams@Comcast.net
Old 03-03-2011, 03:34 PM
Member for 5 years with 8 posts and you come on to slam one of the better replicas out there.
Interesting.
John Hall
Old 03-12-2011, 10:48 AM
cdog's Avatar
To the OP:
You are doing it right.
Left side of shoe on brake, angle foot so you can blip the throttle with right side of shoe. That's what I do.
Question to those that DON'T use heel-toe downshifts: How do you handle accelerating out of a corner since you can downshift while braking? Seems like if you just downshifted and lifted off the clutch, your revs would be all mismatched.
I yanked all that that crap out, properly mounted a tilton dual master cylinder with bias bar and pedals...unfortunately, i learned that the spf brakes, pedals, steering and front geometry must be completely redesigned unless you are just wanting to live with a show car only level of performance on 60's technology tires.
Dude, mine is fine. Car handles good, pedals are fine, stops well. I have Avon tires and I'm betting the car will pull about 1g laterally.
Old 03-12-2011, 10:50 AM
cdog's Avatar
This only applies if you are Tokyo Drifting!
Old 03-15-2011, 11:55 AM
CobraEd's Avatar
Unless you are road racing, there should not be a need for heal/toe downshifting.
________
________
Old 03-15-2011, 03:42 PM
Practice.
I heel and toe the majority of the time that I'm driving.
John Hall
Old 03-15-2011, 06:00 PM
CobraEd's Avatar
I practice double clutching like steve McQueen in Bullit, . . Just in case I ever need it.
________
________
