February 2026
Old 04-06-2011, 06:25 PM
Cobra Make, Engine: Superformance MK III 428CJ
Default speedometer
Spedo not working, removed same from spedo head, but cannot get the cable loose from the angle drive attached between cable and spedo head.
Have checked the nylon gear in tranny it seem ok.
Just don't know how the cable can be that tight on the angle drive, and am afraid of damaging the housing on the angle drive trying to hold it.
Antone have better idea?
thanks, marvin
marvin
Old 04-06-2011, 06:42 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
You may have a speedometer cable self-destruct issue. Could be the cable is jammed at the end preventing the removal of the cable end. Does the cable turn? by hand or drill?
SPFWiringDiagrams@Comcast.net
Old 05-18-2011, 09:08 AM
It's the angle drive reverser gear is bad, need supplyer for the unit.thanks, marvin
marvin
Old 05-18-2011, 09:14 AM
Cobra Make, Engine: #6101 streetbeast Ingelese stack EFI 351w/t-5 9" 4link 3.55
thanks, marvin
If it turns by hand/drill freely, it might be bottoming out in the transmission.
Last edited by littlewave; 05-18-2011 at 09:18 AM.. Reason: didn't see you had the problem solved. hope it works now.
Old 05-18-2011, 10:43 AM
Sailfish's Avatar
Cobra Make, Engine: Superformance #2144 with a Roush 342R (sold June 2018, but still lurking on Club Cobra)
In the event the angle drive is faulty, I'd recommend calling:
Nisonger Instruments
225 Hoyt Avenue
Mamaroneck, NY 10543
Phone: 914.381.1952
Fax: 914.381.1435
They can take care of you. I've used them several times for similar issues and have been very happy with the results.
