Old 05-02-2011, 12:34 PM
Beemer's Avatar
Cobra Make, Engine: Superformance 351 Windsor
Default Replacing Turn Signal Lever
The folks from Hillbank are sending me a replacement turn signal lever since mine is in two pieces after I used it this weekend for a right hand turn. It now hangs by two wires. Has anyone instructions showing what I have to do to replace the broken lever?
Old 05-02-2011, 12:39 PM
Senile Club Cobra Member
You must pull the steering wheel and adaptor from the column, the turn signal switch is them removable after the retaing screw is removed. It is reasonably obvious when you get it apart.
rick@autoventureusa.net
Old 05-02-2011, 12:53 PM
Cobra Make, Engine: SPO 2644 Roush 427R
Never used mine..
Instructions arm up, right turn. arm out, left turn.
Works like a champ, has auto return.
And luckly has never fall'n off...
Old 05-02-2011, 01:06 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
you have a PM
SPFWiringDiagrams@Comcast.net
Old 05-02-2011, 01:33 PM
mickmate's Avatar
SPF have a plug on the end. Nothin to it.
mickmate
http://www.actoncustom.com/
Old 05-03-2011, 09:19 AM
Beemer's Avatar
Thanks for all your comments.
Old 05-03-2011, 10:23 AM
PANAVIA's Avatar
getting to the screw on the switch ( located at 1-2 O'Clock on the column / switch ) is easy, but take special care to protect the dash lip with some sort of masking tape and it would not be a bad idea to protect the gauge faces the same way. a long bladed Phillips screwdriver is your friend in this application ---Steve
