Old 07-28-2011, 07:57 AM
Cobra Make, Engine: SPF 1498, 351 stroker
Default Bleeding the clutch
The reservoir for the slave cylinder has contaminated fluid (dark in color). I want to remove all the contaminated fluid and add the clean. I am not sure if I should force the fluid out while topping it off with new fluid, remove the fluid from the reservoir and then add the new or just open the bleeder and add fluid allowing gravity to slowly remove it while topping it off with new fluid. Any suggestions on the best way to handle this?
